No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Documents
Models
917.378481
Background
The Craftsman Walk Behind Mower 917.378481 is a lawn mower that operates using gasoline. Manufactured by Craftsman, it utilizes a 6.75 HP Briggs & Stratton 4-cycle engine, model 123K02-0273-E1, and has a fuel capacity of 1.6 quarts of unleaded gas. Depending on the temperature, it either uses SAE 30 or SAE 5W-30 oil, with an oil capacity of 20 oz. This mower is equipped with a 21" steel blade, with a blade bolt torque of 35-40 ft-lbs. The spark plug that it uses can either be a Champion RJ19LM or J19LM, with a gap of 0.030".
In terms of features, this lawn mower has an easy pull starter and an operator presence control bar. It is also equipped with a variable speed rear wheel drive and a 7-position height adjustment feature that allows for changes from 1-1/2 to 4 inches. The Craftsman Walk Behind Mower 917.378481 is capable of mulching and is compatible with a rear bag grass catcher. It also includes a folding handle for more compact storage. Regular maintenance such as checking the engine oil before each use, changing the engine oil after every 25 hours of operation, and cleaning the air filter regularly, among others, are necessary to maintain its performance.
Technical Specifications
  • Engine: 6.75 HP Briggs & Stratton 4-cycle engine, model 123K02-0273-E1
  • Fuel capacity: 1.6 quarts (unleaded gas)
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 oz
  • Blade: 21" steel blade
  • Blade bolt torque: 35-40 ft-lbs
  • Spark plug: Champion RJ19LM or J19LM, gap 0.030"
  • Drive: Variable speed rear wheel power propelled drive
  • Height adjustment: 7 position height adjustment from 1-1/2 to 4 inches
  • Mulching capability: Yes
  • Grass catcher compatibility: Rear bag
  • Handle: Folding handle for compact storage
Warranty
The Craftsman Walk Behind Mower 917.378481 comes with a 2-year limited warranty that covers defects in material and workmanship. However, this warranty does not extend to normal wear parts such as belts, blades, and spark plugs. The engine warranty is separately covered by Briggs & Stratton. To claim the warranty, you should contact the manufacturer directly. It is advisable to have the product's details like model number, date of purchase, and a description of the issue at hand ready for smoother processing.
Craftsman 917.378481 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 28
All Time: 606
