No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37771
Background
The Craftsman Walk Behind Mower 917.377710 is a lawn mower designed for residential use. It is gas-powered and propelled by a 7 horsepower Briggs & Stratton engine. The mower has a 21-inch multi-cut blade that can be adjusted to cut grass at a height between 1 and 3.5 inches. It also offers 3-in-1 functionality, which allows for mulching, bagging, and side discharge mowing.
The mower's design includes an on-demand rear wheel drive system, which provides control and maneuverability. It also includes an 8-inch front wheel and a 9-inch rear wheel. The mower has a fuel tank capacity of 1.6 quarts of unleaded gasoline and an oil capacity of 20 ounces. It is recommended to use SAE 30 oil above 32°F and SAE 5W-30 below 32°F. The mower features a folding T-shaped handle for ease of storage.
Technical Specifications
  • Model Number: 917.377710
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 128602-0212-E1, 7.0 hp
  • Fuel tank capacity: 1.6 quarts unleaded gasoline
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 oz
  • Blade: 21" multi-cut
  • Blade bolt torque: 35-40 ft-lbs
  • Wheels: 8" front, 9" rear
  • Cutting height: 1-3.5" adjustable
  • Main Functionality: mulching, bagging, or side discharge mowing
  • Starting Method: Pull start
  • Handle Type: Folding T-shaped handle
Warranty
The Craftsman Walk Behind Mower 917.377710 comes with a 2-year limited warranty provided by Sears. This warranty ensures coverage against any defects in material or workmanship when the mower is utilized for residential purposes. However, it's important to note that the warranty coverage is reduced to just 90 days for commercial or rental use. If you encounter any issues with the mower within the warranty period, you are entitled to claim the warranty. The exact procedures for claiming the warranty would be detailed in the product's owner's manual or could be obtained by contacting Sears' customer service directly.
Craftsman 917.377710 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 12
Past 7 Days: 15
Past 30 Days: 28
All Time: 345
