No Image
This wiki is missing a device image. Help improve this page by uploading one!
6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.377582
Background
The Craftsman Walk Behind Mower 917.377582 is a lawn maintenance tool produced by Roper Corp for Sears. This rear discharge rotary lawn mower has a cutting width of 22 inches and is powered by a 6.75 horsepower Craftsman 4-cycle engine. The mower is designed for use with unleaded regular gasoline and features a displacement of 12.56 cubic inches. It is equipped with a solid state ignition and a 22-inch cutter blade. The deck of the mower is constructed from steel and it has a 9-position height adjustment feature which allows the cutting height to be set between 1 and 3.5 inches.
In terms of operation, the Craftsman Walk Behind Mower 917.377582 is started by pushing the primer five times and then pulling the starter cord. The engine speed is not adjustable and the mower is stopped by releasing the operator presence control bar. The drive system of the mower is engaged by pushing the control lever while holding down the control bar. This mower offers both mulching and bagging capabilities. Regular maintenance of the mower includes checking the engine oil, replacing the air filter, sharpening or replacing the blade, cleaning the underside of the mower deck, lubricating moving parts and checking for loose fasteners.
Technical Specifications
  • Engine: 6.75 horsepower, 4-cycle
  • Engine Model: 143.996704
  • Displacement: 12.56 cubic inches
  • Fuel Type: Unleaded regular gasoline
  • Fuel Capacity: 1.5 quarts
  • Oil Type: SAE 30 (above 32°F), SAE 5W-30 (below 32°F)
  • Oil Capacity: 27 oz.
  • Spark Plug: Champion RJ19LM or J19LM
  • Spark Plug Gap: .030 inches
  • Ignition: Solid state with 0.125 inches air gap
  • Blade Bolt Torque: 35-40 ft. lbs.
  • Cutter Blade: 22 inches
  • Deck Material: Steel
  • Cutting Height: 1-3.5 inches, 9-position adjustment
  • Mulching Capability: Yes
  • Power Propulsion: Drive system
  • Handlebar: Foldable T-shaped
Warranty
The Craftsman Walk Behind Mower 917.377582 comes with a 2-year limited warranty. The warranty covers defects in material and workmanship under normal use and maintenance. It does not specify the exact process of claiming the warranty in this context. However, typical procedures would usually involve contacting the manufacturer or retailer, providing proof of purchase, and describing the nature of the defect. For detailed instructions on how to claim the warranty, it is recommended to refer to the Craftsman 917.377582 Owner's Manual or contact Craftsman customer service directly.
Craftsman 917.377582 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 33
All Time: 467
