No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37754
Background
The Craftsman Walk Behind Mower 917.377540 is a lawn mower designed for residential use. It is powered by a 6.5 horsepower Tecumseh 4-cycle engine and features a 22-inch steel cutting deck. This mower uses unleaded regular gasoline and requires specific types of oil and spark plugs for optimal operation. The mower is equipped with a power propelled rear wheel drive system and offers seven different height adjustments for the cutting deck, ranging from 1-1/2 to 4 inches.
In addition to its core functions, the mower also includes added features such as mulching and rear bagging capabilities and a folding T-shaped handle for more compact storage. It is important to perform regular maintenance on this mower, including checking engine oil before each use, cleaning the underside of the mower deck after each use, and periodically inspecting and replacing the muffler if corroded. Keeping the blade sharp, cleaning the air filter, and changing the spark plug on a yearly basis are also recommended practices for maintaining this mower.
Technical Specifications
  • Model Number: 917.377540
  • Product Type: Walk Behind Mower
  • Engine: 6.5 HP Tecumseh 4-cycle
  • Displacement: 11.5 cu. in.
  • Fuel Type: Unleaded regular gasoline, 1.6 quarts capacity
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F, 20 oz capacity
  • Spark Plug: Champion RJ19LM or J19LM, 0.030 in gap
  • Blade Bolt Torque: 35-40 ft-lbs
  • Valve Clearance: Intake 0.004-0.008 in, Exhaust 0.004-0.008 in
  • Air Gap: 0.0125 in
  • Cutting Deck: 22 inch steel
  • Drive Type: Power propelled rear wheel drive
  • Height Adjustment: 7 position, from 1-1/2 to 4 inches
  • Capabilities: Mulching and rear bagging
  • Handle: Folding T-shaped handle for storage
Warranty
The Craftsman Walk Behind Mower 917.377540 comes with a two-year limited warranty for regular use and a shortened 90-day warranty for commercial or rental use. This warranty does not cover expendable parts, including but not limited to blades, belts, air filters, and spark plugs. Additionally, it does not account for any damage resulting from misuse, lack of maintenance, improper repair, or the use of unapproved attachments. To claim the warranty, refer to the instructions given in the product manual or contact the manufacturer directly.
Craftsman 917.377540 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 10
Past 7 Days: 14
Past 30 Days: 31
All Time: 333
