6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.377301
Background
The Craftsman Walk Behind Mower 917.377301 is a gas-powered lawn mower produced by the Roper Corporation for Sears under the Craftsman brand. This mower is equipped with a 6.6 horsepower Craftsman engine (model 143.976600) with a 12.56 cubic inch displacement. It is designed to function with unleaded regular gasoline with a minimum rating of 87 octane. The oil type recommended for the mower varies with temperature, where SAE 30 is suitable above 32°F and SAE 5W-30 is suitable below 32°F. It has an oil capacity of 27 oz and a fuel capacity of 1.5 quarts. The recommended spark plug for the mower is the Champion RJ19LM, with a gap of .030 in. The blade bolt torque is stated as 35-40 ft-lbs.
This mower features a 22" steel deck, with the ability to adjust the cutting height between 1" and 4" in 7 different positions using a lever on each wheel. It offers three grass clipping disposal options: rear bagging, mulching, and side discharge. The mower is started using a pull cord and uses a variable speed front wheel drive for movement. The handle of the mower is designed to fold for storage and it is equipped with ball-bearing wheels for ease of movement. The mower's engine features a diaphragm carburetor, recoil starter, and transistorized magneto ignition. It is designed to be air-cooled with a pressure lubrication system using an oil sump and pump. The engine speed can be controlled via a throttle located on the side of the engine.
Technical Specifications
  • Model Number: 917.377301
  • Product Type: Walk Behind Mower
  • Manufacturer: Sears, Roebuck and Co.
  • Engine Model: Craftsman 143.976600
  • Engine Displacement: 12.56 cubic inches
  • Horsepower: 6.6 hp
  • Fuel Type: Unleaded regular gasoline, minimum 87 octane
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 27 oz
  • Fuel Capacity: 1.5 quarts
  • Spark Plug: Champion RJ19LM, gap .030 in
  • Blade Bolt Torque: 35-40 ft-lbs
  • Deck Material: Steel
  • Deck Width: 22 inches
  • Height Adjustment: 1" to 4", 7 positions
  • Grass Collection: Rear bagging, mulching or side discharge
  • Starting Method: Pull cord
  • Drive Type: Variable speed front wheel drive
  • Handle: Foldable for storage
  • Wheels: Ball bearing wheels
Warranty
The Craftsman Walk Behind Mower 917.377301 comes with a limited 2-year warranty provided by Sears. This warranty is applicable for non-commercial use of the product. The specifics of what is covered by the warranty are not detailed in the provided text. To claim the warranty, it is typically required to contact the Sears service center or the retailer where the product was purchased. It is recommended to keep the purchase receipt or any other proof of purchase for smooth processing of the warranty claim.
Craftsman 917.377301 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 12
Past 7 Days: 14
Past 30 Days: 35
All Time: 498
