No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37724
Background
The Craftsman Walk Behind Mower 917.377240 is a gas-powered lawn mower, created by Sears. It is equipped with a 21-inch cutting width and has a 7.0 horsepower Briggs & Stratton engine. The mower provides the user with a variety of cutting heights, ranging from 1 to 3.75 inches, with seven positions to choose from. It also has the ability to bag or side discharge the grass clippings. The mower has an electric start feature, however a battery is not included. The mower has front wheels that are 7 inches, and rear wheels that are 8 inches, which allows for easy navigation. The mower weighs approximately 140 pounds.
The Craftsman Walk Behind Mower 917.377240 comes with a steel 21-inch cutting deck. It also has a variable speed rear wheel drive that can reach speeds up to 4.5 mph. There is an operator presence control bar installed for safety purposes. The mower can easily switch between mulching, bagging, and side discharging. It also features a 7-position height adjustment lever. This mower is built with a rust-resistant aluminum deck.
Technical Specifications
  • Model Number: 917.377240
  • Product Type: Walk Behind Mower
  • Manufacturer: Sears
  • Engine: 7.0 HP Briggs & Stratton 128602-0304-E1
  • Cutting Width: 21 inches
  • Cutting Heights: 1-3.75 inches (7 positions)
  • Discharge Capabilities: Rear bagging and side discharge
  • Starting Method: Electric start (battery not included)
  • Wheel Size: Front 7 inches, Rear 8 inches
  • Weight: 140 lbs
  • Deck Material: Steel
  • Drive Type: Variable speed rear wheel drive (up to 4.5 mph)
  • Safety Features: Operator presence control bar
  • Deck Adjustment: 7-position height adjustment lever
  • Deck Material: Rust resistant aluminum
Warranty
The Craftsman Walk Behind Mower 917.377240 comes with a 2-year limited warranty. This warranty covers defects in materials and workmanship but is only applicable for residential use. It is crucial to note that the warranty does not extend its coverage to commercial use, misuse, or damage caused by improper maintenance. In regards to the engine, its warranty is separately provided by Briggs & Stratton. To claim the warranty, you should likely contact the respective companies (Sears for the mower and Briggs & Stratton for the engine), although the specific process isn't outlined in the provided text.
Craftsman 917.377240 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 37
All Time: 722
