2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.377041
Background
The Craftsman Walk Behind Mower 917.377041 is a gas-powered lawn mower that was manufactured by the Roper Corporation for Sears. The mower is equipped with a 160cc Honda 4-cycle engine which uses regular unleaded gasoline with a minimum 87 octane rating. The fuel tank can hold a maximum of 1.0 quarts of fuel, and the oil capacity is 18.5 oz. The engine is designed to function optimally with SAE 30 above 32°F or SAE 10W-30 oil.
The mower has a 21" steel deck with a specially designed mulching blade. The cutting height can be adjusted from 1-1/4" to 4" via a 7-position single point height adjustment lever. Furthermore, it has a variable speed front wheel drive system which is engaged by pulling the drive control lever to the handle. The speed can be adjusted via a turnbuckle on the drive control housing. This mower also comes with rear bagging, side discharge, and mulching capabilities as standard, with an included mulching plug. The product measures approximately 63" H x 21" W x 40" L and weighs 106 lbs.
Technical Specifications
  • Model Number: 917.377041
  • Product Type: Walk Behind Mower
  • Engine: 160cc Honda GCV160-ABHH 4-cycle engine
  • Fuel Type: Regular unleaded gasoline with a minimum 87 octane rating
  • Fuel Tank Capacity: 1.0 quarts
  • Oil Capacity: 18.5 oz SAE 30 above 32°F or SAE 10W-30
  • Cutting Deck: 21" steel deck with special mulching blade
  • Cutting Height: Adjustable from 1-1/4" to 4" via 7-position single point height adjustment lever
  • Drive System: Variable speed front wheel drive system
  • Wheel Dimensions: 8x2 front wheels, 11x2.5 rear wheels
  • Grass Handling: Rear bagging, side discharge, and mulching capabilities
  • Product Dimensions: Approximately 63" H x 21" W x 40" L
  • Product Weight: 106 lbs
Warranty
The Craftsman Walk Behind Mower 917.377041 comes with a 2-year full warranty which covers any manufacturer defects in material or workmanship. However, it is important to note that wear parts such as blades, belts, air filters, and the like are not included in this warranty coverage. If the product is used for commercial or rental purposes, the warranty period is limited to 90 days. In order to claim the warranty, owners should follow the guidelines provided in the product's manual, and may need to provide proof of purchase or other required documents. Warranty claims are likely processed through Sears, as they are the manufacturer of the product.
Craftsman 917.377041 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 28
All Time: 550
