No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Documents
Models
917.376741
Background
The Craftsman 917.376741 is a walk-behind lawn mower with a Briggs & Stratton 124T05 3848-B2 engine. The engine is a four-cycle type with an electric start and a displacement of 163 cc. It has a power rating of 5.5 HP and runs on regular unleaded gasoline with a fuel tank capacity of 1.6 quarts. The oil type used varies with the temperature, with SAE 30 recommended above 32°F and SAE 5W-30 below 32°F, and the oil capacity is 20 ounces.
The mower has a cutting width of 22 inches, with an adjustable cutting height ranging from 1-1/2 to 4 inches across 9 increments. The machine can be used for mulching, rear bagging, and side discharging. It has a variable speed front-wheel drive and a steel deck. The mower weighs 95 lbs and has 7-inch front and 8-inch rear wheels. It is primarily designed for residential yard maintenance.
Technical Specifications
  • Model Number: 917.376741
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 124T05 3848-B2 4-cycle engine with electric start
  • Displacement: 163 cc
  • Power rating: 5.5 HP
  • Fuel tank capacity: 1.6 quarts of unleaded regular gasoline
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 oz
  • Cutting width: 22 inches
  • Cutting height: 1-1/2 to 4 inches in 9 adjustments
  • Mulching capable: Yes, with mulching plug
  • Rear bagging capable: Yes, with grass catcher accessory
  • Side discharge capable: Yes, with side discharge chute accessory
  • Start type: Electric start and recoil start
  • Drive type: Variable speed front wheel drive
  • Deck material: Steel
  • Wheels: 7-inch front, 8-inch rear
  • Weight: 95 lbs
Warranty
The Craftsman 917.376741 lawn mower comes with a 2-year full warranty that covers defects in material and workmanship for non-commercial use. This warranty coverage includes both parts and labor for any covered repairs. However, it's important to note that items that normally wear such as blades, belts, and batteries are not included in the warranty coverage. Also, any abuse or failure to perform necessary maintenance on the mower could possibly void the warranty. If the mower is used for commercial or rental purposes, the warranty period is limited to 90 days.
Craftsman 917.376741 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 39
All Time: 678
