2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376723
Background
The Craftsman Walk Behind Mower is a lawn mower created by the company Craftsman. The mower uses a Briggs & Stratton engine and has a 22-inch cutting width. The mower's engine speed is not adjustable. The wheels on this product can be raised and lowered to adjust the cutting height.
This device is run on gasoline but it comes without gasoline and oil.
The Craftsman Walk Behind Mower includes a grass catcher to collect grass clippings. This device also comes with a mulcher plug to convert the mower into a mulcher.
Sources:
Craftsman Walk Behind Mower User Manual
Identification
The Craftsman Walk Behind Mower has a 22-inch, circular-shaped deck housing. There are four wheels attached to the deck housing: two small wheels are in the front, and two large wheels are in the back. There is a Briggs & Stratton engine on top of the deck housing. The engine oil cap and gasoline cap are located on the rear end engine of the engine near the mower's handle respectively.
A rectangular-shaped grass catcher is attached to the back of the deck housing, and the Craftsman logo is printed on both sides of the grass catcher. A mulcher door is located on the right side of the deck housing.
This device is distinguishable from other models by its black and yellow engine. The model number and serial number can be found on a decal on the front side of the lawn mower.
Sources:
Craftsman Walk Behind Mower Parts
Technical Specifications
Gasoline:
  • Capacity: 1.6 qts
  • Type: Unleaded Regular
Oil:
  • Capacity: 20 oz
  • Type: API SG-SL
  • Viscosity Grade: SAE 30 (above 32F); SAE 5W-30 (below 32F)
Blade Bolt Torque:
  • Weight: 35-40 ft lbs
Spark Plug:
  • Gap: .030 in
  • Type: Champion RJ19LM or J19LM
Source:
Additional Information
Craftsman Official Site
Craftsman Outdoor Equipment Maintenance Tips
Craftsman Parts & Service Centers
Craftsman 917.376723 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 43
All Time: 907
