No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376692
Background
The Craftsman Walk Behind Mower 917.376692 is a lawn mower with a self-propulsion feature. It is powered by a 5.5 horsepower Honda GCV160 4-stroke engine. The mower has a 21-inch cutting width and offers 6 adjustable settings for cutting heights ranging from 1-1/4 to 3-3/4 inches. The variable speed front wheel drive system allows it to move at adjustable speeds controlled by the operator. The mower uses a 21-inch steel blade that can both mulch and bag grass clippings.
The mower functions on a quart of regular unleaded gasoline and has an oil capacity of 18.5 ounces. The height of the blade can be easily adjusted via a lever on each wheel. The speed of the mower is controlled by adjusting the drive cable tension. The mower features an operator presence control bar and an engine zone control cable which stops the blade when the handle is released. The mower starts with a manual recoil starter, and the engine speed is fixed and non-adjustable by the user. Maintenance tasks include checking engine oil and air filter, sharpening or replacing the blade, lubricating wheels, and cleaning under the mower deck.
Technical Specifications
  • Model Number: 917.376692
  • Product Type: Walk Behind Mower
  • Engine: 5.5 horsepower Honda GCV160 4-stroke engine
  • Fuel Capacity: 1 quart (uses regular unleaded gasoline)
  • Oil Capacity: 18.5 ounces
  • Cutting Width: 21 inches
  • Cutting Heights: Adjustable from 1-1/4 to 3-3/4 inches (6 settings)
  • Drive System: Variable speed front wheel drive
  • Blade: 21 inch steel mulching/bagging blade
  • Safety Features: Operator presence control bar, engine zone control cable
  • Starter: Manual recoil starter
  • Speed: Fixed and not user adjustable
  • Drive Control: Engaged via drive control lever
  • Clipping Disposal: Mulch, bag or discharge
  • Maintenance: Checking engine oil and air filter, sharpening/replacing the blade, lubricating wheels, and cleaning under the mower deck
  • Engine Oil Change: After the first 5-8 hours of use and every 25 hours thereafter
  • Air Filter Replacement: Every 100 hours or annually
Warranty
The Craftsman Walk Behind Mower 917.376692 comes with a 2-year limited warranty. This warranty covers any defects in the materials and the workmanship of the product. However, it is important to note that the warranty does not extend to normal wear parts or damage resulting from improper use or maintenance. To claim the warranty, refer to the owner's manual for the specific procedures. It is crucial to retain your purchase receipt as it may be required as proof of purchase date.
Craftsman 917.376692 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 44
All Time: 515
