No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376691
Background
The Craftsman 917.376691 is a walk-behind lawn mower. It is equipped with a Honda GCV160 engine, a 4-stroke OHC engine with a capacity of 160 cc and horsepower of 5.5 HP. This lawn mower uses unleaded gasoline with a fuel capacity of 1.0 quarts. The oil used is either SAE 30 (above 32°F) or SAE 10W-30, with a capacity of 18.5 oz. The lawn mower has a cutting width of 21 inches and offers seven adjustments for cutting heights ranging from 1-3/4" to 4".
The Craftsman 917.376691 has various mowing options, including mulching, rear bagging, and side discharge. It is equipped with self-propelled drive and has 7-inch front wheels and 11-inch rear wheels. The mower weighs 95 lbs and has a steel deck housing. The mower requires regular maintenance, including checking the engine oil before each use, changing the engine oil every 25 hours of use, and cleaning the air filter every 25 hours of use. The blade needs to be inspected prior to each mowing and sharpened as needed.
Technical Specifications
  • Model Number: 917.376691
  • Product Type: Walk Behind Mower
  • Engine: Honda GCV160, 160 cc, 5.5 HP, 4-stroke OHC
  • Fuel Type: Unleaded gasoline
  • Fuel Capacity: 1.0 quarts
  • Oil Type: SAE 30 (above 32°F), SAE 10W-30
  • Oil Capacity: 18.5 oz
  • Cutting Width: 21 inches
  • Cutting Heights: 1-3/4" to 4" in 7 adjustments
  • Mulching Capabilities: Yes
  • Rear Bag Capabilities: Yes
  • Side Discharge Capabilities: Yes
  • Electric Start Capabilities: Yes
  • Self-Propelled Drive: Yes
  • Front Wheel Size: 7 inches
  • Rear Wheel Size: 11 inches
  • Weight: 95 lbs
Warranty
The Craftsman 917.376691 walk behind mower comes with a 2-year limited warranty. This warranty specifically covers defects in materials and workmanship when the mower is used for non-commercial purposes. It's important to note that the warranty becomes void if the mower is used for commercial or rental purposes. Additionally, parts that are subject to normal wear and tear, such as blades, belts, and brake pads, are excluded from the warranty. The engine has a separate warranty that is covered by Honda. In order to claim the warranty, you should review the owner's manual for detailed instructions. It is typically necessary to provide proof of purchase and contact the manufacturer or authorized dealer.
Craftsman 917.376691 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 585
