2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376674
Background
The Craftsman Walk Behind Mower 917.376674 is a gas-powered lawn mower with a 22-inch cutting width. This model is equipped with a Briggs & Stratton 122T02 engine, which has a power rating of 3.5 HP. The machine has a self-propelled, variable speed rear wheel drive system, allowing users to control the speed as needed. It uses a recoil start mechanism. The fuel tank capacity is 1.6 quarts, and it uses SAE 30 oil above 32°F and SAE 5W-30 oil below 32°F, with an oil capacity of 20 ounces.
The mower's functionality includes mulching, rear bagging, and side discharging. The cutting deck is composed of steel, and the cutting height can be adjusted to 7 different positions ranging from 1 to 3.75 inches. The handle of the mower is adjustable and foldable, which aids in storing the mower more compactly. This model is designed for residential use and requires regular maintenance for optimal performance, such as checking the engine oil level before each use, changing the engine oil every 25 hours of operation, lubricating the wheels and hinges, and cleaning the underside of the mower after each use.
Technical Specifications
  • Engine: Briggs & Stratton 122T02, 127cc
  • Engine power: 3.5 HP
  • Cutting width: 22 inches
  • Cutting height: 1-3.75 inches, 7 positions
  • Drive type: Self-propelled, variable speed rear wheel drive
  • Starting method: Recoil start
  • Fuel tank capacity: 1.6 quarts
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 ounces
Warranty
The Craftsman Walk Behind Mower 917.376674 comes with a full warranty that lasts for 2 years. This warranty covers any defects in materials and workmanship under non-commercial use. However, if the mower is used commercially, the warranty period is shortened to 90 days from the date of purchase. To claim the warranty, one should refer to the procedures outlined in the product's user manual or contact the manufacturer, Sears, directly.
Craftsman 917.376674 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 36
All Time: 680
