2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376583
Background
The Craftsman Walk Behind Mower 917.376583 is a gas-powered lawn mower produced by Sears. The mower is equipped with a Briggs & Stratton 6.75 HP 4-cycle engine, which uses a recoil start system and an automatic choke, eliminating the need for manual priming or choking. The mower has a cutting width of 22 inches and allows for a range of cutting heights between 1.5 and 4 inches, adjustable through 9 different positions.
In terms of its drive system, it uses a variable speed front wheel drive, which is controlled by a drive control lever that enables self-propulsion. For grass handling, it offers two options - mulching and rear bagging. The mulching plug allows for efficient recycling of grass clippings back into the lawn, while the optional rear bagger provides the option to collect and dispose of clippings separately. The mower weighs approximately 55 lbs and has dimensions of 22L x 19W x 14H inches. It's suitable for mowing small to medium sized yards.
Technical Specifications
  • Engine Type: Briggs & Stratton 6.75 HP 4-cycle engine, model 125K02-0500-E1
  • Starting Method: Recoil start
  • Choke Type: Automatic choke (no priming or choking required)
  • Cutting Width: 22 inches
  • Cutting Height Range: 1.5-4 inches
  • Height Adjusters: 9 position height adjusters
  • Drive System: Variable speed front wheel drive
  • Drive Control: Drive control lever engages self-propulsion
  • Safety Control: Operator presence control bar stops engine when released
  • Rear Deflector: Shields operator from debris
  • Grass Handling: 2-in-1 mulching and rear bagging capability
  • Additional Features: Mulching plug for mulching grass clippings, Optional rear bagger for collecting clippings
  • Weight: Approximately 55 lbs
  • Dimensions: 22L x 19W x 14H inches
Warranty
The Craftsman Walk Behind Mower 917.376583 comes with a 2-year limited warranty. While the specific details of what is covered under this warranty are not explicitly mentioned in the document, it typically includes manufacturer defects and issues that arise under normal use conditions. To claim the warranty, it is usually required to contact the manufacturer directly or the retailer where the product was purchased, although these details are not explicitly stated in the document provided. It is recommended to keep the purchase receipt and any other related documents for warranty claims.
Craftsman 917.376583 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 30
All Time: 737
