No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376572
Background
The Craftsman Walk Behind Mower 917.376572 is a lawn mower that operates on gasoline and is designed for cutting grass. This mower has a 22 inch cutting width and is powered by a Briggs & Stratton engine with 6.75 horsepower. The mower uses unleaded regular gasoline with a fuel capacity of 1.6 quarts. It has an oil capacity of 20 ounces with SAE 30 oil being used above 32°F and SAE 5W-30 below 32°F.
This mower can be used for mulching, bagging or side discharge of grass clippings. It has a variable speed rear-wheel drive, which gives the user control over the speed of the mower. The cutting height can be adjusted between 1 and 3.5 inches, with seven different positions available. The mower has 7 inch front wheels and 11 inch rear wheels. The mower requires regular cleaning after each use to prevent the buildup of grass clippings and debris. Additionally, regular maintenance such as oil changes and air filter replacements are required to keep the mower operating efficiently.
Technical Specifications
  • Engine: Briggs & Stratton 125K02-0500-E1, 6.75 HP
  • Fuel: Unleaded regular gasoline, 1.6 quarts capacity
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 ounces
  • Spark Plug: Champion RJ19HX, gap .030 inches
  • Blade Bolt Torque: 35-40 ft-lbs
  • Cutting Width: 22 inches
  • Cutting Height: 1-3.5 inches, 7 positions
  • Wheels: 7 inch front, 11 inch rear
  • Weight: 75 lbs
Warranty
The Craftsman Walk Behind Mower 917.376572 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship for a period of 2 years from the date of purchase. However, normal wear parts like belts, blades, and brake pads are not included in this warranty. For the engine, a separate warranty is provided by Briggs & Stratton. If the product encounters any issues within the warranty period, refer to the Craftsman's warranty claim procedures to address the problem.
Craftsman 917.376572 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 36
All Time: 620
