2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37647
Background
The Craftsman Walk Behind Mower 917.376470 is a gas-powered lawn mower that is designed for use in residential settings. This model is equipped with a 22-inch cutting width and can adjust to seven different height settings between 1-3/4" to 4". The mower is fueled by a Briggs & Stratton 126T05-0678-B1 4-cycle engine with a displacement of 163 cc and a torque of 5.5 ft-lbs. The fuel capacity is 1.6 quarts of unleaded regular gasoline, and it requires 20 oz of SAE 30 oil for temperatures above 32°F and SAE 5W-30 for temperatures below 32°F.
The Craftsman Walk Behind Mower 917.376470 also comes with an operator presence control bar and a variable speed front wheel drive. The machine starts with an electric start system and also includes a recoil backup. It is designed with a steel deck and has 7-inch front and 8-inch rear wheels. The mower is capable of mulching, and it is compatible with rear bag and side discharge methods. The handle of the machine can be folded for storage purposes. The machine weighs 66 lbs.
Technical Specifications
  • Model Number: 917.376470
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 126T05-0678-B1 4-cycle engine
  • Displacement: 163 cc
  • Power: 5.5 ft-lbs torque
  • Fuel Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Capacity: 20 oz SAE 30 oil (above 32°F), SAE 5W-30 (below 32°F)
  • Cutting Width: 22 inches
  • Cutting Height: 1-3/4" to 4" in 7 adjustments
  • Drive System: Variable speed front wheel drive
  • Starter: Electric start with recoil backup
  • Deck Material: Steel
  • Wheels: 7-inch front / 8-inch rear wheels
  • Weight: 66 lbs
Warranty
The Craftsman Walk Behind Mower 917.376470 comes with a 2-year full warranty provided by Sears Holdings Corporation, covering any defects that may arise due to materials or workmanship. However, it's important to note that if the mower is utilized for commercial purposes, the warranty duration is reduced to 90 days. The warranty does not include coverage for normal wear items. To claim the warranty, it is typically necessary to contact Sears Holdings Corporation, provide evidence of the defect, and follow their specific procedures. Be sure to retain a copy of your purchase receipt as it may be required for warranty claims.
Craftsman 917.376470 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 34
All Time: 652
