2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37645
Background
The Craftsman Walk Behind Mower 917.376450 is a gas-powered lawn mower designed for trimming and maintaining lawns. It is equipped with a Briggs & Stratton 126T02-1045-B1 4-cycle engine with a displacement of 126 cc, and a horsepower of 3.5 hp. The unit operates on unleaded gasoline, with a fuel capacity of 1.6 quarts. The mower is designed to handle a variety of lawns with its adjustable cutting width of 22 inches and adjustable cutting height ranging from 1 to 3.5 inches. It is capable of mulching, rear bagging, and side discharging.
This particular model of Craftsman mower is self-propelled, requiring less physical effort from the user. It is equipped with 7-inch front wheels and 8-inch rear wheels, both of which can be adjusted in height. The mower also has an electric start feature for effortless ignition. Its Briggs & Stratton engine has an automatic choke and zone start speed control for easy starting. The drive system operates on a variable speed front wheel drive that engages when the operator bail is held against the handle, with speed adjusted by the drive control. The mower's handle can also be adjusted to different height positions for user comfort.
Technical Specifications
  • Model Number: 917.376450
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 126T02-1045-B1 4-cycle engine
  • Engine Displacement: 126 cc
  • Horsepower: 3.5 hp
  • Fuel Type: Unleaded gasoline, 87 octane minimum
  • Fuel Capacity: 1.6 quarts
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Cutting Width: 22 inches
  • Cutting Height: 1-3.5 inches (9 positions)
  • Mulching Capabilities: Yes
  • Rear Bag Compatible: Yes
  • Side Discharge Compatible: Yes
  • Electric Start Capable: Yes
  • Front Wheels: 7 inches
  • Rear Wheels: 8 inches
Warranty
The Craftsman Walk Behind Mower 917.376450 comes with a 2-year full warranty that covers any defects in material and workmanship. This warranty is applicable for both residential and commercial use, although commercial use is only covered for a period of 90 days from the date of purchase. However, please note that normal wear items such as oil, spark plugs, air filters, and blades are not included under the warranty coverage. To claim the warranty, you would likely need to contact the manufacturer or retailer with proof of purchase and details about the defect or issue.
Craftsman 917.376450 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 30
All Time: 523
