2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376406
Background
The Craftsman Walk Behind Mower 917.376406 is a gas-powered lawn mower, designed for residential use and manufactured by Roper Corp for Sears. This mower is propelled by a Briggs & Stratton 126T02-1443-B1 4-cycle engine, with a 126cc displacement. It uses unleaded regular gasoline and has a fuel capacity of 1.6 quarts. The mower's engine uses SAE 30 oil at temperatures above 32°F and SAE 5W-30 oil at temperatures below 32°F. It has an oil capacity of 20 oz.
The walk-behind mower has a cutting width of 22 inches and the cutting height can be adjusted between 1-3/4 and 3-3/4 inches. It offers the user the flexibility of mulching, rear bagging, or side discharge options. The mower is self-propelled with rear wheel drive and features variable speed control. The mower's dimensions are approximately 63"L x 23"W x 40"H and it weighs around 150 lbs.
Technical Specifications
  • Engine Type: 4-cycle engine
  • Engine Manufacturer: Briggs & Stratton 126T02-1443-B1
  • Engine Displacement: 126cc
  • Choke Type: Automatic
  • Fuel Type: Unleaded regular gasoline
  • Fuel Capacity: 1.6 quarts
  • Oil Type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
  • Oil Capacity: 20 oz
  • Cutting Width: 22 inches
  • Cutting Height Adjustment: 1-3/4"- 3-3/4"
  • Cutting Options: Mulching, rear bagging, and side discharge
  • Blade Torque: 35-40 ft-lbs
  • Drive Type: Self-propelled rear wheel drive
  • Speed Control: Variable
  • Dimensions: approx 63"L x 23"W x 40"H
  • Weight: Approx 150 lbs
Warranty
The Craftsman Walk Behind Mower 917.376406 comes with a 2-year full warranty. This warranty covers any defects in material or workmanship, although it excludes any damage from commercial use. Additionally, there is a shorter 90-day warranty specifically for commercial or rental use. However, it's important to note that the warranty does not provide coverage for normal wear parts such as the blade, belt, air filter, and spark plug. It also doesn't cover any damage resulting from improper use or lack of maintenance. To claim the warranty, one should follow the manufacturer's recommended procedures, which usually involve providing proof of purchase and directly contacting the manufacturer or authorized service centers.
Craftsman 917.376406 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 675
