2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376403
Background
The Craftsman Walk Behind Mower 917.376403 is a lawn mower designed for residential use. It is operated by a Briggs & Stratton 126T02-1346-B1 engine with a displacement of 163 cc and a power rating of 5.5 hp. The mower uses unleaded gasoline and has a fuel capacity of 1.6 quarts. The cutting width is 22 inches, and the cutting height is adjustable from 1-3/4" to 3-3/4". It also features a recoil starter, variable speed rear wheel drive, and a steel deck.
This lawn mower is versatile in its use, offering both self-propelled and push drive types. It comes with a grass collection capacity of 2.4 bushels, either through a rear bag or a mulching plug. The mower's weight is 75 lbs and it operates with 7 inch front wheels and 8 inch rear wheels. The mower requires regular maintenance, including engine oil changes, air filter and spark plug replacements, and mower blade sharpening or replacements.
Technical Specifications
  • Model Number: 917.376403
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 126T02-1346-B1 4-cycle OHV
  • Displacement: 163 cc
  • Power Rating: 5.5 hp
  • Fuel Type: Unleaded gasoline, 87 octane minimum
  • Fuel Capacity: 1.6 quarts
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Cutting Width: 22 inches
  • Cutting Height: 1-3/4" to 3-3/4" adjustable
  • Starter: Recoil
  • Transmission: Variable speed rear wheel drive
  • Blade Speed: 3600 rpm
  • Drive Type: Push or self-propelled
  • Deck Material: Steel
  • Wheels: 7 inch front, 8 inch rear
  • Grass Collection: 2.4 bushel rear bag or mulching plug
  • Weight: 75 lbs
Warranty
The Craftsman Walk Behind Mower 917.376403 comes with a comprehensive 2-year full warranty. This warranty covers any defects in both material and workmanship for a duration of 2 years from the date of purchase, given that the product is used for residential purposes. However, if the product is used commercially, the warranty period is reduced to only 90 days from the purchase date. Note that the warranty does not cover parts that undergo normal wear, any damage resulting from improper use or abuse, or failure due to inadequate maintenance based on the guidelines provided in the operator's manual. To claim the warranty, refer to the procedures outlined in the product's documentation, typically involving providing proof of the purchase date and detailing the nature of the defect.
Craftsman 917.376403 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 18
All Time: 366
