6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37639
Background
The Craftsman Walk Behind Mower 917.376390 is a self-propelled, gas-fueled mower. It is designed with a Briggs & Stratton 126T02-1225-EA 4-cycle engine, which does not require priming or choking before starting. The mower is equipped with a variable speed rear-wheel drive, which is engaged by pulling the drive control bar up to the handle. The speed can be adjusted based on how close the bar is to the handle.
The mower comes with a 22-inch steel mowing deck, and the cutting height can be adjusted from 1-1/4 to 4 inches in 6 increments. It can be set up as a mulcher, but also has the capability to convert to rear bagging or side discharge modes. The mower is designed to stop when the operator presence control bar is released. It utilizes unleaded gasoline with a 1.6-quart capacity and SAE 30 oil above 32°F or SAE 5W-30 below 32°F. The mower weighs 60 lbs and includes a muffler to reduce noise and emissions. Other features include a folding T-shaped handle, 7-inch front wheels, and 8-inch rear wheels.
Technical Specifications
  • Model Number: 917.376390
  • Product Type: Walk Behind Mower
  • Engine: 4-cycle engine with automatic choke
  • Self-propelled: Variable speed rear-wheel drive
  • Cutting Width: 22 inch steel mowing deck
  • Cutting Height: Adjusts from 1-1/4 to 4 inches in 6 increments
  • Mulching/Bagging/Side Discharge: Convertible with included attachments
  • Operator Presence Control: Bar needs to be held down to start and operate
  • Weight: 60 lbs
  • Fuel Type: Unleaded gasoline, 1.6 quart capacity
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F, 20 oz capacity
  • Handle: Folding T-shaped handle
  • Wheels: 7 inch front wheels, 8 inch rear wheels
  • Blade Brake: Stops blade within 3 seconds after releasing operator presence control bar.
Warranty
The Craftsman Walk Behind Mower 917.376390 comes with a warranty period of 2 years, offering full coverage against any defects in material or workmanship. However, if the mower is used for commercial purposes, the warranty duration is reduced to 90 days. To claim the warranty, one would typically need to contact the manufacturer, Sears, with details of the defect. It is advisable to have proof of purchase and details of the specific issue at hand to ensure a smooth claim process.
Craftsman 917.376390 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 11
Past 7 Days: 14
Past 30 Days: 35
All Time: 401
