No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37629
Background
The Craftsman Walk Behind Mower 917.376290 is a rear discharge rotary lawn mower with a 22-inch cutting width. Manufactured by Roper Corp for Sears, this mower is a part of the 300 series of Craftsman mowers. It has a 6.0 horsepower engine for propulsion and is capable of variable speed due to its front wheel drive system. It accommodates seven height positions, ranging from 1 to 3.75 inches, allowing it to adapt to different grass lengths.
This walk behind mower is equipped with dual lever controls for managing drive speed and engine speed. It has the ability to perform multiple functions including mulching, bagging, or side discharge, depending on the user's preference. An optional grass catcher for the rear can be acquired separately. The mower's design incorporates a folding handle, which allows for more compact storage when not in use. The engine runs on unleaded gasoline, and the oil capacity is 20 oz. The fuel capacity of the mower is 1.25 quarts, and it weighs approximately 95 lbs.
Technical Specifications
  • Model Number: 917.376290
  • Product Type: Walk Behind Mower
  • Engine: 6.0 HP
  • Displacement: 125 cc
  • Cutting Width: 22 inches
  • Cutting Height: 1-3.75 inches (7 positions)
  • Drive: Variable speed front wheel drive
  • Speed Control: Dual lever - Drive control and engine speed
  • Mulching Capable: Yes
  • Grass Catcher: Optional accessory
  • Start Type: Recoil
  • Fuel Type: Unleaded gasoline
  • Oil Type: SAE 30
  • Oil Capacity: 20 oz
  • Fuel Capacity: 1.25 quarts
  • Weight: approx 95 lbs
Warranty
The Craftsman Walk Behind Mower 917.376290 comes with a 2-year limited warranty for regular use and a 90-day limited warranty if used commercially. The specifics of what the warranty covers are not explicitly mentioned in the document, therefore it is recommended to refer to the detailed warranty information in the product's user manual or contact the manufacturer. To claim the warranty, it is usually required to produce proof of purchase, and contacting customer service or the manufacturer's warranty department is often the first step. However, the exact process may vary and should be confirmed by reviewing the warranty terms provided with the product or on the manufacturer's website.
Craftsman 917.376290 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 11
Past 7 Days: 14
Past 30 Days: 23
All Time: 256
