6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376221
Background
The Craftsman Walk Behind Mower 917.376221 is a push lawn mower with a 22" cutting width. It is manufactured by Roper Corp for Sears under the Craftsman Brand and is powered by a Briggs & Stratton 124T02-1227-EA 163cc engine. The mower is equipped with a variable speed front wheel drive system and has 7" plastic front wheels and 8" plastic rear wheels. The machine weighs 60 lbs.
In terms of features, the mower has a deck size of 22" and can cut grass at heights ranging from 1.25" to 3.75". The mower is equipped with a dual lever, allowing for easy adjustment of the cutting height. It also has the capability for mulching and rear bagging, with a 2.5 bushel grass catcher included. Additionally, there's a side discharge chute for managing grass clippings. The mower comes with an automatic choke for easy starting and a dual trigger control for engaging and disengaging both the drive and blades. Regular maintenance of the mower includes checks and changes of engine oil, replacement of air filter and spark plug, and cleaning of the underside of the mower deck to prevent grass clippings buildup.
Technical Specifications
  • Model Number: 917.376221
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 124T02-1227-EA 163cc 5.5 ft-lbs gross torque
  • Deck size: 22" cutting width
  • Cutting heights: 1.25" - 3.75" in 7 adjustments
  • Mulching capability: Yes
  • Rear bagging capability: Yes, with included 2.5 bushel grass catcher
  • Side discharge capability: Yes, with included side discharge chute
  • Drive system: Variable speed front wheel drive
  • Wheels: 7" plastic front wheels, 8" plastic rear wheels
  • Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower 917.376221 comes with a warranty that spans over two years from the date of the product purchase. This warranty is designed to cover any defects in materials or workmanship that might occur during this time period. To claim the warranty, the product can be taken to any Sears nationwide service center where repair or replacement will be carried out free of charge. However, it's important to note that normal wear items such as blades, belts, and filters are not included in this warranty coverage. Additionally, the engine has a separate warranty which is managed by Briggs & Stratton.
Craftsman 917.376221 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 602
