5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376165
Background
The Craftsman Walk Behind Mower 917.376165 is a gas-powered lawn mower designed for residential use. The main feature of this mower is its 22-inch wide mowing deck, which is equipped with a multi-cut blade for effective grass cutting. The mower is powered by a 6.75 horsepower Briggs & Stratton engine, which facilitates reliable performance.
The mower's variable speed front-wheel drive allows the user to adjust the speed to suit their mowing needs. It also has a 7-position height adjustment feature, offering choices from 1-3/4 inches to 3-3/4 inches for the cutting height. The mower comes with a rear grass catcher with a capacity of 2.4 bushels, offering the option of bagging the grass clippings. It also has mulching and side discharge capabilities, providing flexibility in how the grass clippings are managed. The mower's handle is T-shaped and foldable, providing ease of storage when not in use.
Technical Specifications
  • Model Number: 917.376165
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 6.75 HP 125K02-0658-E1
  • Displacement: 190cc
  • Fuel Tank Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Blade: 22" multi-cut
  • Blade Bolt Torque: 35-40 ft-lbs
  • Spark Plug: Champion J19LM or RJ19LM, gap .030"
  • Drive: Variable speed front wheel
  • Cutting Height: 1-3/4" to 3-3/4" in 7 adjustments
  • Grass Catcher Capacity: 2.4 bushels
Warranty
The Craftsman Walk Behind Mower 917.376165 comes with a 2-year limited warranty. This warranty period starts from the date of purchase and covers defects in material and workmanship that may arise under normal use and maintenance. However, it does not cover damage caused by misuse, abuse, neglect or failure to operate the product in accordance with instructions provided in the owner's manual. To claim the warranty, you should retain your receipt as proof of purchase, and contact the Craftsman customer service. They will guide you through the process which may involve returning the product or parts to an authorized service center.
Craftsman 917.376165 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 370
