5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.376061
Background
The Craftsman Walk Behind Mower 917.376061 is a gas-powered lawn mower with a 22-inch cutting deck. It is manufactured by Sears and uses a 6.75 HP Briggs & Stratton engine. This model has a displacement of 125 cc and a fuel tank that can hold 1.6 quarts of unleaded gasoline with a minimum octane of 87. The engine uses SAE 30 oil above 32°F and SAE 5W-30 below 32°F, with an oil capacity of 20 oz.
This walk-behind mower has a range of technical specifications that allow it to handle different mowing conditions. It features a cutting height that is adjustable between 1 and 3.5 inches, with 7 different positions available. The mower includes both mulching and rear bagging capabilities. It also has an electric start feature, and 9 inch front wheels and 7 inch rear wheels for maneuverability. The handle of the mower is height adjustable and can be folded down for storage. The mower is intended for residential use and is not recommended for commercial applications.
Technical Specifications
  • Engine: Briggs & Stratton 6.75 HP
  • Displacement: 125 cc
  • Fuel Tank Capacity: 1.6 quarts
  • Fuel Type: Unleaded gasoline, 87 octane minimum
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Cutting Width: 22 in
  • Cutting Height: 1-3.5 in (7 positions)
  • Grass Management: Mulching and rear bagging capability
  • Wheel Size: 9 inch front wheels, 7 inch rear wheels
  • Start Method: Electric start capable
Warranty
The Craftsman Walk Behind Mower 917.376061 comes with a full warranty that lasts for 2 years. This warranty covers any defects that may arise due to materials or workmanship. However, it's worth noting that if the mower is used for commercial purposes, the warranty period is reduced to 90 days. The warranty does not extend to normal wear items such as blades, belts, and filters. To claim the warranty, you would typically need to refer back to the operator's manual or contact the manufacturer directly, although the specific process is not outlined in this document.
Craftsman 917.376061 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 680
