No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.374452
Background
The Craftsman Walk Behind Mower 917.374452 is a gas-powered lawn maintenance tool produced by Roper Corp for Sears. This model is designed to cut grass of varying heights ranging from 1 inch to 4 inches, which can be adjusted through a single point height adjuster lever.
The mower includes features that allow for different grass disposal methods. With the installation or removal of the mulcher plug and discharge deflector, the mower can switch between rear bagging, side discharging, or mulching modes. The machine is fueled by unleaded regular gasoline (87 octane minimum) with a capacity of 1.6 quarts and uses either SAE 30 oil above 32°F or SAE 5W-30 below 32°F, with an oil capacity of 20 ounces. The engine is started by priming the engine and pulling the starter handle quickly. The speed of the mower is controlled by the drive control lever with the propulsion stopping when the lever is released.
Technical Specifications
  • Model Number: 917.374452
  • Product: Craftsman Walk Behind Mower 917.374452
  • Product Type: Walk Behind Mower
  • Fuel Type: Gasoline
  • Gasoline Capacity: 1.6 quarts unleaded regular (87 octane minimum)
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 ounces
  • Spark Plug: Champion RC12YC, gap .030"
  • Blade Bolt Torque: 35-40 ft-lbs
  • Cutting Height: Adjustable from 1" to 4" in 1/4" increments
  • Modes: Can be converted for rear bagging, side discharging or mulching modes.
Warranty
The Craftsman Walk Behind Mower 917.374452 comes with a two-year limited warranty for non-commercial use. This warranty covers any defects in materials and workmanship from the date of purchase. However, it does not extend to normal wear and tear, misuse, or inadequate maintenance. The warranty also covers emission control system components for a period of two years, as mandated by EPA regulations. Safety apparel associated with the mower has a separate warranty period of 90 days. To claim the warranty, one must provide proof of purchase and report the issue within the warranty period. It's essential to remember that any modifications or unauthorized repairs could potentially void the warranty.
Craftsman 917.374452 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 22
All Time: 314
