6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.374366
Background
The Craftsman Walk Behind Mower 917.374366 is a gas-powered lawn mower. Manufactured by Roper Corp for Sears, it is a self-propelled mower, meaning it moves forward on its own without requiring manual push. The mower operates with a Briggs & Stratton 128T05-1268-B1 engine, which has a displacement of 127cc and a power output of 3.5 HP. The engine uses unleaded gasoline with a minimum octane rating of 87 and has a fuel capacity of 1.6 quarts.
The mower's cutting mechanism comprises a steel blade that can be set to seven different height positions, ranging from 1 to 3.75 inches. It features a steel deck of 22 inches in width. The mower is started via an electric start button, however, it also features a recoil starter for backup. It drives with variable speed controlled by a lever on the handle, and it weighs approximately 66 lbs. The mower also includes a mulching plug, and there is an option to attach a rear grass bag.
Technical Specifications
  • Model Number: 917.374366
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 128T05-1268-B1 127cc engine
  • Displacement: 127 cc
  • Power: 3.5 HP
  • Fuel type: Unleaded gasoline, 87 octane minimum
  • Fuel capacity: 1.6 quarts
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 oz
  • Cutting width: 22 in
  • Cutting height: 1-3.75 in (7 positions)
  • Blade type: Steel
  • Starter: Electric start with recoil backup
  • Transmission: Variable speed front wheel drive
  • Deck material: Steel
  • Weight: 66 lbs
Warranty
The Craftsman Walk Behind Mower 917.374366 comes with a 2-year full warranty that safeguards against any manufacturer defects. This warranty entails coverage for both parts and labor if necessary. However, it's important to note that the warranty becomes void if the mower is used for commercial purposes or is improperly maintained. Normal wear items, such as oil, spark plugs, blades, and belts, are not included under the warranty coverage.
Craftsman 917.374366 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 38
All Time: 712
