2 Diagrams
Documents
Models
917.374356
Background
The Craftsman Walk Behind Mower 917.374356 is a gas-powered lawn mower designed for manual operation. Manufactured by Roper Corp for Sears, this lawn mower is equipped with a Briggs & Stratton 128T02-1270-B1 4-cycle engine that has an automatic choke. The engine has a displacement of 127 cc and produces 3.75 horsepower. A notable feature of this model is its 22-inch cutting width, which is capable of 6 different height adjustments ranging from 1-1/2" to 4".
The Craftsman Walk Behind Mower 917.374356 operates on regular unleaded gasoline, with a fuel capacity of 1.6 quarts. It has an oil capacity of 20 oz, which requires SAE 30 oil above 32 degrees Fahrenheit and SAE 5W-30 below 32 degrees Fahrenheit. The mower has dual lever height adjusters, 7-inch front wheels and 8-inch rear wheels. Additional features include operator presence control bar, and mulching, bagging, and side discharge capabilities. The mower has a folding handle which allows for compact storage.
Technical Specifications
  • Engine: Briggs & Stratton 128T02-1270-B1 4-cycle engine with automatic choke
  • Displacement: 127 cc
  • Horsepower: 3.75 HP
  • Fuel Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Capacity: 20 oz SAE 30 oil (above 32°F); SAE 5W-30 (below 32°F)
  • Cutting Width: 22 inches
  • Cutting Height: 6 adjustable positions from 1-1/2" to 4"
  • Wheel Size: 7 inch front and 8 inch rear wheels
  • Operation Controls: Operator presence control bar
  • Discharge Options: Mulching, bagging and side discharge capabilities
  • Starting System: Easy start automatic choke
  • Storage: Folding handle for compact storage
Warranty
The Craftsman Walk Behind Mower 917.374356 is covered under a warranty by the manufacturer. This warranty is valid for a period of 2 years for residential use, and 90 days if the mower is used commercially. The warranty is comprehensive, covering the entire mower. To claim the warranty, one would need to adhere to the guidelines provided in the product's owner's manual, or contact Sears directly. It's important to note that the warranty may only be valid if the product has been used and maintained as per the manufacturer's guidelines.
Craftsman 917.374356 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 34
All Time: 832
