No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37226
Background
The Craftsman model 917.372260 is a walk-behind lawn mower, designed with a 22" cutting width. It is powered by a Sears 143.384092 4-cycle engine, with a displacement of 140 cc and a horsepower of 4.0 HP. The engine runs on unleaded gasoline and uses SAE 30W oil. The mower is equipped with a variable speed rear wheel drive and uses a 22" steel blade for cutting. The cutting height can be adjusted between 1 1/8" to 3 3/8" with five different positions. Grass clippings are collected in a 2.4 bushel rear bag. The mower's weight is 80 lbs.
The mower features a zone start safety system, requiring the operator to be located behind the unit to start the engine. The T-shaped handle can be adjusted to a high or low position. The mower discharges grass clippings into a rear bag and can also be fitted with an optional side discharge chute. Maintenance of the mower includes regular engine oil changes, spark plug replacements, air filter replacements, cleaning the underside of the mower deck, blade replacements, and lubricating the wheels and rear door hinge annually. It is recommended to always follow the procedures in the operator's manual for maintenance.
Technical Specifications
  • Model Number: 917.372260
  • Product Type: Walk Behind Mower
  • Engine: 4-cycle engine
  • Engine Displacement: 140 cc
  • Horsepower: 4.0 HP
  • Fuel Type: Unleaded gasoline
  • Oil Type: SAE 30W
  • Cutting Width: 22 inches
  • Cutting Height: Adjustable between 1 1/8" to 3 3/8" (5 positions)
  • Drive Type: Variable speed rear wheel drive
  • Blade: 22" steel blade
  • Grass Collection: 2.4 bushel rear bag
  • Weight: 80 lbs
Warranty
The Craftsman walk behind mower model 917.372260 comes with a 2-year limited warranty, provided routine maintenance is performed. This warranty covers the engine of the product. If the product is used for commercial purposes, the warranty coverage is limited to 90 days. To claim the warranty, it's expected that routine maintenance has been observed, such as changing engine oil after the first two hours of use and every 25 hours thereafter, replacing the spark plug and air filter annually, keeping the underside of the mower deck clean, replacing the blade when worn and lubricating wheels and rear door hinge annually. For more detailed information on how to claim the warranty or any maintenance procedures, refer to the operator's manual that accompanies the product.
Craftsman 917.372260 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 11
Past 7 Days: 17
Past 30 Days: 35
All Time: 321
