6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37193
Background
The Craftsman Walk Behind Mower 917.371930 is a push mower with a 22-inch deck, manufactured by Roper Corp for Sears. It is equipped with a 126cc Briggs & Stratton 4-stroke overhead valve engine, delivering an output of 3.75 horsepower. This mower features a fuel tank capacity of 1.6 quarts and requires SAE 30 or SAE 5W-30 oil, depending on the temperature. The device also has an oil capacity of 20 oz.
In terms of its capabilities, the mower has a deck width of 22 inches and offers seven different cutting height positions between 1 and 3.75 inches. It can perform mulching, rear bagging, and side discharge. The mower employs an EZ Walk system, which consists of a padded handle with adjustable height settings. The engine uses an easy pull starting system and automatic choke. The mower is fitted with 7-inch front wheels and 8-inch rear wheels and weighs 60 lb. The maintenance of this mower includes regular oil changes, air filter replacements, spark plug replacements and blade sharpening.
Technical Specifications
  • Engine: 126cc Briggs & Stratton 4-stroke overhead valve
  • Displacement: 126cc
  • Power: 3.75 hp
  • Fuel tank capacity: 1.6 quarts
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 oz
  • Mower deck width: 22 in
  • Cutting height: 1-3.75 in (7 positions)
  • Mulching capability: Yes
  • Rear bagging capability: Yes
  • Side discharge capability: Yes
  • Wheel size: 7 in front, 8 in rear
  • Weight: 60 lb
Warranty
The Craftsman Walk Behind Mower 917.371930 comes with a standard 2-year manufacturer's warranty. This warranty typically covers defects in materials or workmanship that may occur during normal use. To claim the warranty, customers are usually required to contact the manufacturer directly, in this case, Sears. They will need to provide the product's model number and proof of purchase. It's important to note that warranty terms may vary, so it is always recommended to refer to the specific warranty information provided in the user manual or product documentation for detailed instructions and conditions.
Craftsman 917.371930 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 25
All Time: 396
