6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.371031
Background
The Craftsman Walk Behind Mower 917.371031 is a gas-powered lawn mower with a cutting width of 21 inches. It uses a Briggs & Stratton 11P905-1267-B1 163cc OHV engine and has a fuel capacity of 1.6 quarts of unleaded regular gasoline. The machine has an oil capacity of 18 oz of SAE 30 oil. It offers an adjustable cutting height between 1 and 3 inches. This mower also has a variable speed rear wheel drive and a steel deck type. The start type is electric with a push backup. In addition, it has a 21-inch steel blade.
The Craftsman Walk Behind Mower 917.371031 has several features such as dual ball bearing wheels, a 7 position height adjustment lever, and an operator presence control bar. It can be used in three different ways: mulching, rear bagging, and side discharge. The mower also has an electric start ignition.
Technical Specifications
  • Engine: Briggs & Stratton 11P905-1267-B1 163cc OHV
  • Fuel Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Capacity: 18 oz SAE 30 oil
  • Cutting Width: 21 inches
  • Cutting Height: 1-3 inches adjustable
  • Drive Type: Variable speed rear wheel drive
  • Deck Type: Steel
  • Start Type: Electric start with push backup
  • Blade: 21 inch steel
  • Wheel Type: Dual ball bearing wheels
  • Height Adjustment: 7 position lever
  • Discharge Capabilities: Mulching, rear bagging, and side discharge
Warranty
The Craftsman Walk Behind Mower 917.371031 comes with a 2-year limited warranty, intended to cover any defects in materials and workmanship under non-commercial use. This warranty covers the costs of both parts and labor for the repairs of any covered defects. However, it's important to note that wear items such as belts, blades, and tires are not included in the warranty coverage. Moreover, the warranty will be voided if the product incurs damage from misuse, abuse, or failure to properly maintain the mower. To claim the warranty, contact the authorized Craftsman service center and provide the necessary details about your product and the issue you're facing.
Craftsman 917.371031 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 34
All Time: 406
