2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.370925
Background
The Craftsman Walk Behind Mower 917.370925 is a gas-powered lawn mower. It was manufactured by Roper Corp for Sears under the Craftsman brand. The mower is equipped with a 22-inch steel deck and is powered by a Briggs & Stratton 128M02-1612-F1 163cc engine.
The mower uses unleaded gasoline and has a fuel capacity of 1.6 quarts. It also requires oil, with a capacity of 18-20 ounces, which varies depending on temperature conditions. The cutting height can be adjusted in 7 increments between 1 and 3.5 inches. The mower features 8-inch front wheels and 11-inch rear wheels, and it weighs 66 pounds. It starts via a recoil starter and has a side-discharge muffler. The blade is a 22-inch steel blade. The mower also includes an operator presence control bar, a folding upper handle, single point height adjustment functionality, and options for rear bagging, mulching, or side discharge.
Technical Specifications
  • Model Number: 917.370925
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 128M02-1612-F1 163cc
  • Power: 5.5 ft-lbs torque
  • Fuel: Unleaded gasoline
  • Oil: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Fuel Capacity: 1.6 quarts
  • Oil Capacity: 18-20 ounces
  • Deck Size: 22" steel deck
  • Cutting Height: 1-3.5" in 7 adjustments
  • Front Wheels: 8" plastic
  • Rear Wheels: 11" plastic
  • Weight: 66 lbs
  • Starting Mechanism: Recoil starter
  • Muffler: Side discharge
  • Blade: 22" steel blade
  • Additional Features: Operator presence control bar, Folding upper handle, 7-position single point height adjustment, Rear bagging, mulching or side discharge, 11" rear wheels
Warranty
The Craftsman Walk Behind Mower 917.370925 comes with a 2-year limited warranty provided by Sears Brands Management. This warranty covers any defects in materials or workmanship for a duration of two years from the date of purchase. However, it's important to note that the warranty doesn't extend to normal wear parts such as belts, blades, and air filters. Damages due to improper use or accidents, as well as repairs done by unauthorized service centers, aren't covered under the warranty. Additionally, the engine warranty is separately handled by Briggs & Stratton. In order to claim the warranty, customers would typically need to contact the manufacturer or the authorized service center, usually providing proof of purchase and details about the defect or issue.
Craftsman 917.370925 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 374
