6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37077
Background
The Craftsman Walk Behind Mower 917.370770 is a lawn mower that is manoeuvred by the user walking behind it. This mower, produced by Sears, has a 21-inch multi-cut rotary blade and uses power propulsion with variable speed rear wheel drive. It also incorporates an electric push button start.
The mower is powered by a 127cc Briggs & Stratton OHV engine and employs a key start electric ignition. The cutting height is adjustable in 6 positions from 1-3/4" to 4". It uses a steel deck and a 21" mulching/standard blade. The grass collection capacity is 2.4 bushels with a rear bag. The mower has 7-inch front wheels and 8-inch rear wheels, and its weight is 155 lbs. Its features include a 6 position height adjustment lever, mulching, rear bagging and side discharge capability, easily convertible clipping options, and an operator presence control bar.
Technical Specifications
  • Model Number: 917.370770
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 126T05-1070-B1 127cc OHV
  • Ignition: Key start electric
  • Cutting Width: 21 inches
  • Cutting Height: Adjustable from 1-3/4" to 4" in 6 positions
  • Drive: Variable speed rear wheel drive
  • Deck Material: Steel
  • Blade: 21" mulching/standard blade
  • Grass Collection: 2.4 bushel rear bag
  • Wheel Size: 7" front / 8" rear
  • Weight: 155 lbs
Warranty
The Craftsman Walk Behind Mower 917.370770 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship when the product is put to non-commercial use. The warranty also extends to the engine for the same duration. To claim the warranty, it is typically required to provide proof of purchase and details about the defect or issue encountered. The exact procedure can vary, so it's recommended to contact the manufacturer or retailer directly for specific instructions.
Craftsman 917.370770 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 37
All Time: 516
