2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.370752
Background
The Craftsman Walk Behind Mower 917.370752 is a rotary lawn mower that operates on gas. It is manufactured by the Roper Corp for Sears under the Craftsman brand. The mower is equipped with a Briggs & Stratton 126T02-1055-B1 190cc 4-cycle engine. The cutting width of the mower is 21 inches, and it offers a variable cutting height between 1-3/4 inches to 3-3/4 inches with 9 adjustable positions. The mower is self-propelled and features a variable speed front wheel drive mechanism.
The Craftsman Walk Behind Mower 917.370752 operates through a recoil start method and has a fuel capacity of 1.6 quarts of unleaded gasoline. It also has an oil capacity of 20 ounces of SAE 30 oil. The mower offers three grass management options: rear bag, mulch, or side discharge. It also features an adjustable handle with three positions and large 8-inch wheels at the front and rear. To start the mower, gasoline and oil are added and the operator presence control bar is lifted to the handle, pulling the starter handle quickly. The engine typically starts on the first or second pull when cold. To engage the blade, the operator presence control bar is held down. Releasing the bar will stop the engine and the blade. To propel the mower, the drive control bar is lifted up to the handle. To stop movement, the drive control is released. The cutting height lever is used to adjust the blade height.
Technical Specifications
  • Model Number: 917.370752
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 126T02-1055-B1 190cc 4-cycle engine
  • Cutting Width: 21 inches
  • Cutting Height: 1-3/4 inches to 3-3/4 inches (9 positions)
  • Drive Type: Self-propelled, variable speed front wheel drive
  • Start Type: Recoil start
  • Fuel Capacity: 1.6 quarts unleaded gasoline
  • Oil Capacity: 20 ounces SAE 30 oil
  • Cutting Deck: Durable steel 21 inch with multicut blades
  • Height Adjustment: 9 position lever for varied cutting height
  • Torque: 7.0 ft-lbs, sufficient for most mowing conditions
  • Safety Feature: Operator presence control bar
  • Discharge Options: Rear bag, mulch or side discharge
  • Handle: Ergonomic adjustable handle with 3 positions
  • Wheels: Large 8 inch front and rear wheels
  • Starter: Easy pull recoil starter
Warranty
The Craftsman Walk Behind Mower 917.370752 comes with a 2-year full warranty. This warranty covers the entire product and is provided by the manufacturer, Sears. It guarantees the product to be free from defects in material or workmanship and ensures the replacement or repair of parts without charge within the warranty period. To claim the warranty, it is likely that the owner will need to provide proof of purchase and contact the manufacturer directly, though the specific claim process is not detailed in the provided text.
Craftsman 917.370752 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 24
All Time: 418
