6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.370691
Background
The Craftsman Walk Behind Mower 917.370691 is a lawn mower produced by Sears Brands. The mower is gas-powered and comes equipped with a 22" steel mowing deck. The mower is driven by a 163cc Briggs & Stratton engine that produces 6.0 ft-lbs of gross torque.
This lawn mower is self-propelled and features rear-wheel drive with variable speed control. It also provides the option of an electric start with a backup recoil starter. The mower allows for 7 different height adjustments, ranging from 1-1/4 to 3-3/4 inches. It is designed to use unleaded regular gasoline with a minimum octane rating of 87 and has a fuel capacity of 1.6 quarts. The mower is capable of both mulching and rear bagging due to its 2-in-1 functionality.
Technical Specifications
  • Model Number: 917.370691
  • Product Type: Walk Behind Mower
  • Engine Model: Briggs & Stratton 163cc OHV
  • Engine Displacement: 163cc
  • Engine Power: 6.0 ft-lbs gross torque
  • Fuel Capacity: 1.6 quarts
  • Fuel Type: Unleaded regular gasoline, 87 octane minimum
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Cutting Width: 22 inches
  • Cutting Height: 1-1/4" to 3-3/4" (7 positions)
  • Wheel Size: 7" front, 8" rear
  • Weight: 75 lbs
  • Drive Type: Self-propelled rear-wheel drive with variable speed control
  • Starting Mechanism: Electric start with backup recoil starter
  • Mowing Functionality: 2-in-1 functionality for mulching or rear bagging
Warranty
The Craftsman Walk Behind Mower 917.370691 comes with a 2-year full warranty. This warranty covers any defects in material or workmanship for a period of two years from the date of purchase. However, it's important to note that the warranty does not cover normal wear parts or issues arising from improper use or lack of maintenance. In order to claim the warranty, one would typically need to provide proof of purchase and report the issue within the warranty period. Specific instructions on how to claim the warranty might vary, so it's always recommended to check the owner's manual or contact the manufacturer for the exact procedure.
Craftsman 917.370691 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 26
All Time: 709
