6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37068, 917.370680
Background
The Craftsman Walk Behind Mower 917.370680 is a gas-powered rotary lawn mower, manufactured by Roper Corp for Sears under the Craftsman brand. It operates with a Briggs & Stratton 128T02-1270-B1 4-cycle engine, with a capacity of 126cc and 3.75 ft-lbs gross torque. Its cutting width measures 22 inches, and it offers a cutting height that can be adjusted between 1-3/4 inches to 4 inches. The mower is equipped with a variable speed rear wheel drive system and a manual recoil start. It includes a 22-inch steel blade and a steel deck, and is fitted with 7-inch front wheels and 8-inch rear wheels. The mower can hold up to 1.6 quarts of 87+ octane unleaded gasoline and 18-20 ounces of SAE 30 or SAE 5W-30 oil.
The Craftsman 917.370680 is a self-propelled walk-behind mower with a variable speed rear wheel drive system. The cutting height can be adjusted using a dual lever height adjustment system, which provides six height positions. This mower offers three options for grass clippings: mulching, rear discharge, or side discharge. The mower deck is made of steel and the handles can be folded for convenient storage. To operate, the user fills the gas tank, adjusts the cutting height, and starts the mower manually. For effective mowing, the user should mow in a smooth pattern, overlapping slightly for even cutting. Regular maintenance includes checking the engine oil level and cleaning the mower deck after each use.
Technical Specifications
  • Engine: Briggs & Stratton 128T02-1270-B1 4-cycle engine, 126cc and 3.75 ft-lbs gross torque
  • Cutting Width: 22 inches
  • Cutting Height: 1-3/4 inches to 4 inches in 6 adjustable heights
  • Drive System: Variable speed rear wheel drive
  • Start Type: Manual recoil start
  • Blade: 22 inch steel blade
  • Deck Material: Steel
  • Wheels: 7 inch front wheels, 8 inch rear wheels
  • Gasoline Capacity: 1.6 quarts, 87+ octane unleaded gasoline
  • Oil Capacity: 18-20 ounces, SAE 30 or SAE 5W-30 oil
  • Weight: 70 lbs
Warranty
The Craftsman Walk Behind Mower 917.370680 comes with a 2-year limited warranty, provided by Sears. This warranty typically covers any defects in material or workmanship. To claim the warranty, it's usually required to provide proof of purchase such as a receipt and contact the Sears customer service or a Sears authorized service center. Specific warranty details and claim procedures can be found in the product's operator's manual or by contacting Sears directly.
Craftsman 917.370680 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 34
All Time: 1,134
