2 Diagrams
Documents
Models
917.37066
Background
The Craftsman Walk Behind Mower 917.370660 is a gas-powered lawn mower that is designed for residential use. Its main feature is its 22-inch steel mower deck, which is powered by a 126T05-1561-B1 Briggs & Stratton engine. This engine provides a power output of 6.75 foot-pounds torque at 3,600 RPM. The mower also includes both recoil and electric start options, and allows for 7 different height adjustments ranging from 1-1/2" to 4".
Additional specifications include a cutting width of 22 inches, a displacement of 125cc, and a weight of 60 lbs. The mower is capable of mulching, and is also compatible with rear bag and side discharge options. The fuel tank can hold up to 1.6 quarts, and the oil capacity is 20 ounces. The mower uses SAE 30 oil above 32°F and SAE 5W-30 below 32°F. The blade bolt torque is 35-40 ft-lbs. Overall, the Craftsman Walk Behind Mower 917.370660 is designed to provide a reliable and customizable mowing experience.
Technical Specifications
  • Model Number: 917.370660
  • Product Type: Walk Behind Mower
  • Manufacturer: Sears Brands
  • Engine: Briggs & Stratton 126T05-1561-B1
  • Power Output: 6.75 foot-pounds torque at 3,600 RPM
  • Deck Size: 22" steel mower deck
  • Starting Mechanism: Recoil and electric start
  • Height Adjustment: 7-position height adjustment from 1-1/2" to 4"
  • Cutting Width: 22 inches
  • Displacement: 125cc
  • Deck Material: Steel
  • Cutting Height: 1-1/2" to 4" (7 positions)
  • Additional Features: Mulching capable, rear bag compatible, side discharge compatible
  • Weight: 60 lbs
  • Fuel Tank Capacity: 1.6 quarts
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Blade Bolt Torque: 35-40 ft-lbs
Warranty
The Craftsman Walk Behind Mower 917.370660 comes with a 2-year full warranty. This warranty covers defects in materials and workmanship. However, it is important to note that expendable parts such as belts, blades, and filters are not covered under this warranty. Likewise, damages resulting from improper maintenance or modifications, as well as damages from accessories not approved by Sears are not covered. Furthermore, repairs needed due to improper fuel mixture or stale fuel are not included in the warranty. The warranty is void if the mower is used commercially or rented to others.
Craftsman 917.370660 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 31
All Time: 853
