2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.370601
Background
The Craftsman Walk Behind Mower 917.370601 is a rotary lawn mower that operates on a 160cc Honda GCV160 engine. Its primary features include a 22-inch cutting width, a variable speed drive control, and a self-propulsion mechanism. The engine is air-cooled, 4-stroke, and has an overhead cam. It is capable of a horsepower of 5.5 hp. In terms of fuel and oil capacities, the mower can hold up to 1.0 quarts of regular unleaded gasoline and 0.58 quarts of oil. The oil type required is API SG-SL, and the spark plug used is the NGK BPR6ES with a gap of 0.030".
This lawn mower has a cutting height that ranges from 1 to 3.75 inches, adjustable in 9 positions. It enables three grass management options: mulching, rear discharge, and bagging. The mode of operation requires the operator's presence control bar to be held down to start the engine, and releasing it stops the engine. Furthermore, the variable speed self-propelled drive is controlled by a drive bar. Maintenance includes regular cleaning, particularly under the deck to remove clippings buildup, and the underside can be flushed out with a garden hose. The engine oil and air filter require regular changes as per the engine maintenance schedule.
Technical Specifications
  • Model Number: 917.370601
  • Product Type: Walk Behind Mower
  • Engine: Honda GCV160, 160cc, overhead cam, air-cooled, 4-stroke
  • Horsepower: 5.5 hp
  • Fuel tank capacity: 1.0 quarts (regular unleaded gasoline)
  • Oil capacity: 0.58 quarts
  • Oil type: API SG-SL
  • Spark plug: NGK BPR6ES, gap 0.030"
  • Blade bolt torque: 35-40 ft-lbs
  • Cutting width: 22"
  • Cutting height: 1-3.75" (9 position adjustment)
  • Features: Mulching and rear bagging capabilities
Warranty
The Craftsman 917.370601 walk-behind mower comes with a 2-year full warranty. This warranty covers any defects in materials and workmanship that may occur during normal use of the product. However, it is important to note that the warranty does not extend to consumable parts such as blades, belts, or filters. The engine warranty is handled separately by Honda. To claim this warranty, refer to the documentation provided with the product or contact the manufacturer directly. It is generally recommended to keep proof of purchase for warranty purposes.
Craftsman 917.370601 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 60
All Time: 1,295
