2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.370581
Background
The Craftsman Walk Behind Mower 917.370581 is a gas-powered lawn mower with a 21-inch cutting width. Manufactured by Roper Corp for Sears under the Craftsman brand, it is equipped with a 650 Series Briggs & Stratton engine. Notably, this model has an electric start capability, which requires a battery. The mower is designed with a variable speed rear wheel drive that can be adjusted using a drive lever located near the top of the handlebars.
The lawn mower enables the user to adjust the cutting height between 1 to 3.5 inches across nine different positions. These adjustments are made using a lever on each wheel. The mower can mulch, bag, or side discharge grass clippings. The mulching and discharging functions are managed by manipulating a rear mulcher door and a side discharge chute. The mower is fitted with 7 inch front wheels and 8 inch rear wheels, and features a folding T-shaped handlebar.
Technical Specifications
  • Model Number: 917.370581
  • Product Type: Walk Behind Mower
  • Manufacturer: Sears
  • Engine: 650 Series Briggs & Stratton engine
  • Fuel Type: Gasoline
  • Fuel Capacity: 1.6 quarts (unleaded regular)
  • Oil Type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
  • Oil Capacity: 20 ounces
  • Start Method: Electric start models (battery required)
  • Transmission: Variable speed rear wheel drive
  • Cutting Width: 21 inches
  • Cutting Height: 1-3.5 inches (9 height positions)
  • Grass Handling: Mulch, rear bag (optional), and side discharge
  • Wheel Size: Front wheels 7 inches, Rear wheels 8 inches
  • Handlebar: Folding T-shaped design
Warranty
The Craftsman Walk Behind Mower 917.370581 comes with a 2-year warranty provided by Sears. This warranty essentially covers any defects in the material or workmanship of the product. To claim the warranty, the owner is advised to refer to the detailed information provided in the owner's manual. This manual carries instructions about assembly, operation, maintenance schedules and troubleshooting, as well as details about repair parts. In case of any issues, the owner should follow the outlined procedures in the manual to ensure successful warranty claim.
Craftsman 917.370581 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 26
All Time: 513
