2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37043
Background
The Craftsman Walk Behind Mower 917.370430 is a self-propelled, gas-powered lawn mower. It is equipped with a Briggs & Stratton 126M02-1525-F1 4-cycle engine with 126 cc displacement. This lawn mower has a fuel capacity of 1.6 quarts of unleaded gasoline and an oil capacity of 20 ounces SAE 30 oil. The cutting width of the mower is 22 inches and it has a cutting height between 1 and 3.75 inches, which can be adjusted to 6 different heights. The mower has 7-inch front wheels and 8-inch rear wheels, and is started with a recoil start. The transmission is a variable speed rear-wheel drive, and the blade is a 22-inch steel blade. The weight of the mower is 160 lbs.
In terms of features, the Craftsman Walk Behind Mower 917.370430 has a 22-inch mowing deck made of steel, a single lever for adjusting the cutting height, an easy pull recoil starter, and a Briggs & Stratton engine with 6.5 ft-lbs of torque. It has the capability to discharge grass clippings from the side, mulch them, or collect them in a rear bag. The mower has dual point height adjusters for an even cut and a control bar that requires operator presence. The operation of the mower involves adding oil and gas, setting the cutting height with the side levers, priming the engine, and pulling the starter cord. The rear wheel drive is engaged by squeezing the control bar and pushing the drive bar.
Technical Specifications
  • Model Number: 917.370430
  • Product: Craftsman Walk Behind Mower 917.370430
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 126M02-1525-F1 4-cycle engine with 126 cc displacement
  • Fuel capacity: 1.6 quarts of unleaded gasoline
  • Oil capacity: 20 ounces SAE 30 oil
  • Cutting width: 22 inches
  • Cutting height: 1-3.75 inches in 6 adjustable heights
  • Wheels: 7 inch front wheels, 8 inch rear wheels
  • Starting: Recoil start
  • Transmission: Variable speed rear-wheel drive
  • Blade: 22 inch steel blade
  • Weight: 160 lbs
Warranty
The Craftsman Walk Behind Mower 917.370430 comes with a 2-year limited warranty. This warranty covers defects in materials and workmanship, but only for non-commercial use. It's important to note that this warranty does not extend to normal wear parts like belts, blades, and filters. The engine warranty is covered separately by Briggs & Stratton. To claim the warranty, one should contact the manufacturer or the seller, providing details about the defect along with proof of purchase.
Craftsman 917.370430 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 38
All Time: 1,363
