2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.370433
Background
The Craftsman Walk Behind Mower 917.370433 is a gas-powered rotary lawn mower designed for cutting grass. It is produced by Roper Corp for Sears and features a 22-inch width cutting system with multi-cut blades, making it capable of handling larger lawns. The mower is also equipped with a rear bagging system, which conveniently collects grass clippings for disposal or composting.
This walk-behind mower is powered by a 675 Series Briggs & Stratton engine, with a displacement of 163 cc. It has a fuel tank capacity of 1.6 quarts and uses either SAE 30 or SAE 5W-30 oil depending on the temperature. The mower offers a flexible cutting height range from 1-3/4" to 4" with nine different positions. The mower can also function in mulching mode or side discharge mode, according to the user's preference.
Technical Specifications
  • Model Number: 917.370433
  • Engine: 675 Series Briggs & Stratton
  • Displacement: 163 cc
  • Power: 5.5 ft-lbs Gross Torque
  • Fuel Tank Capacity: 1.6 Quarts (Unleaded Regular Gasoline)
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 18 oz
  • Cutting Width: 22 inches
  • Cutting Height: 1-3/4" – 4" (9 positions)
  • Weight: 60 lbs
  • Mulching Capable: Yes
  • Rear Grass Bagging Capable: Yes
  • Side Discharge Capable: Yes
  • Adjustment: Dual lever height adjustment
  • Rear Wheels Size: 8 inch
  • Cutting System: 3-in-1
Warranty
The Craftsman Walk Behind Mower 917.370433 comes with a 2-year full warranty that covers any defects in material and workmanship. However, this warranty does not extend to expendable parts such as belts, blades, or filters which may wear out due to normal use within the warranty period. To claim the warranty, refer to the procedures specified by the manufacturer or the retailer where the product was purchased. It is generally advisable to keep the purchase receipt and warranty card safe for a seamless warranty claim process.
Craftsman 917.370433 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 28
All Time: 586
