6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.370431
Background
The Craftsman Walk Behind Mower 917.370431 is a rotary lawn mower produced by Roper Corp for Sears under the Craftsman brand. This gas-powered mower is equipped with a 22-inch steel deck and offers 3-in-1 capabilities, allowing for mulching, bagging, and side discharging of grass clippings.
The mower is powered by a Briggs & Stratton 126M02-1525-F1 163cc OHV engine and runs on unleaded gasoline. It offers a variable speed front-wheel drive and 7 different height adjustment settings. The mower has a recoil start system and comes with adjustable plastic wheels. The product is designed to be versatile, offering different options for handling grass clippings, and the handles can be easily folded for storage.
Technical Specifications
  • Engine: Briggs & Stratton 126M02-1525-F1 163cc OHV
  • Fuel Capacity: 1.6 quarts unleaded gasoline (87 octane min)
  • Oil Type: 18 oz SAE 30 (above 32°F) or SAE 5W-30 (below 32°F)
  • Cutting Width: 22 inches
  • Cutting Height: 1-3/4 to 4 inches (7 positions)
  • Discharge Options: Can convert between mulching, rear bagging or side discharging with attachments
  • Start Method: Recoil start
  • Drive Type: Variable speed front-wheel drive
  • Rear Wheel Size: 7 inch plastic wheels
  • Front Wheel Size: Adjustable 6 inch plastic wheels
  • Deck Material: Steel
  • Blade Torque: 35-40 ft-lbs
Warranty
The Craftsman Walk Behind Mower 917.370431 comes with a 2-year full warranty against defects in material or workmanship. This warranty is limited for commercial usage. It covers the repair or replacement of defective parts only, with exclusions applying for normal wear, improper use, or maintenance. To claim the warranty, it is typically necessary to contact Sears, provide proof of purchase, and describe the nature of the defect. The exact process may vary, so it's recommended to consult the product's manual or contact Sears for specific steps.
Craftsman 917.370431 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 64
All Time: 1,748
