2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.37999
Background
The Craftsman 21" Walk Behind Mower 247.379990 is a lawn mower driven by a Briggs & Stratton engine. It is fueled by unleaded gasoline and uses SAE 30 oil. This model is equipped with a 21-inch steel blade and offers a cutting width of the same size. The cutting height can be adjusted between 1 to 3 inches. It also features a variable speed front-wheel drive, a 2.5 bushel capacity grass catcher, and a mulching capability.
The mower is designed with a dual-lever variable speed front wheel drive and a six-position height adjustment lever. Other features include an ergonomic adjustable handle and an easy pull recoil starter. The mower is designed for diverse mowing conditions and can be maintained by checking the engine oil before use, changing the engine oil annually, replacing the air filter and spark plug annually, sharpening the blade annually, and cleaning the underside of the mower deck regularly.
Technical Specifications
  • Model Number: 247.379990
  • Engine Type: Briggs & Stratton
  • Engine Displacement: 163 cc
  • Fuel Type: Unleaded gasoline
  • Oil Type: SAE 30
  • Cutting Width: 21 inches
  • Cutting Height: Adjustable, 1-3 inches
  • Drive Type: Variable speed front wheel
  • Blade Type: 21 inches steel
  • Mulching Capability: Yes
  • Grass Catcher: Included, 2.5 bushel capacity
Warranty
The Craftsman 21" Walk Behind Mower 247.379990 comes with a 2-year limited warranty provided by Sears. This warranty covers any defects in materials and workmanship for a period of 2 years from the date of purchase. However, this warranty does not extend to normal wear and tear, modifications, or damages caused by improper maintenance or misuse of the product. To claim the warranty, proof of purchase is required, hence, it is important to keep any receipts or documents that confirm the date and place of purchase.
Craftsman 247.379990 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 31
All Time: 838
