20 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.37744
Background
The Craftsman Walk Behind Mower 247.377440 is a gas-powered lawn mower produced by Sears Brands. This machine's primary attribute is its Briggs & Stratton engine with a displacement of 163 cc. It uses unleaded gasoline as fuel and SAE 30 as oil. The mower is equipped with a 21-inch cutting deck, which can be adjusted to cut grass between 1 and 3.75 inches in height across seven available positions. The mower can be powered on both manually, using the recoil starter, or electrically with a rechargeable battery and push key start.
This mower is a self-propelled walk-behind model with variable speed rear-wheel drive, which can be controlled via a squeeze lever on the handlebar. It can either discharge grass clippings from the side or mulch them back onto the lawn. This mower also includes a 2.4 bushel rear grass collection bag. The mower should be serviced annually, including an oil change, new spark plug, blade inspection, and air filter cleaning. The blade can be removed and sharpened or replaced as necessary. Before storing, it is recommended to empty the fuel system and thoroughly clean the mower to prevent corrosion. The rechargeable battery needs to be kept fully charged when not in use to maximize its lifespan.
Technical Specifications
  • Engine: Briggs & Stratton
  • Engine displacement: 163 cc
  • Fuel type: Unleaded gasoline
  • Oil type: SAE 30
  • Cutting width: 21 in
  • Cutting height: 1-3.75 in (7 positions)
  • Drive type: Variable speed rear wheel drive
  • Electric start: Yes, with rechargeable battery and push key start
  • Mulching capable: Yes
  • Grass catcher: 2.4 bushel bag
Warranty
The Craftsman Walk Behind Mower 247.377440 comes with a 2-year limited warranty. This warranty primarily covers any defects in the materials and workmanship of the product. However, it does not extend to expendable parts such as oil filters, belts, and blades which are susceptible to wear and tear through regular use. For the engine, a separate warranty is provided by Briggs & Stratton. To claim the warranty, you would need to follow the specific procedures set by the manufacturers, which usually involve providing proof of purchase and detailing the nature of the defect or issue.
Craftsman 247.377440 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 994
