2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.3749
Background
The Craftsman Walk Behind Mower 247.374900 is a lawn mower designed for personal use. It operates on unleaded gasoline with a minimum octane rating of 87. The mower is equipped with a Briggs & Stratton 128M02-0952-F1 engine and a displacement of 0.95 L. It delivers a power of 5.75 ft-lbs gross torque. The mower is self-propelled, featuring variable speed front wheel drive, and starts with a recoil starter.
The mower has a cutting width of 21 inches, and the cutting height can be adjusted between 1 and 3.75 inches. It has 7 different height positions selectable with a lever. It also includes a 21-inch steel blade and a 2.5 bushel fabric grass catcher. The device weighs 66 lbs. This lawn mower can be used to discharge grass clippings from the side or mulch them back into the lawn.
Technical Specifications
  • Engine: Briggs & Stratton 128M02-0952-F1 with 0.95 L displacement
  • Power: 5.75 ft-lbs gross torque
  • Fuel: Unleaded gasoline, minimum 87 octane
  • Oil: SAE 30 oil, 18 oz capacity
  • Cutting Width: 21 in
  • Cutting Height: 1-3.75 in, 7 position adjustment
  • Drive: Variable speed front wheel drive
  • Start: Recoil starter
  • Blade: 21 in steel mulching blade
  • Grass Collection: 2.5 bushel fabric grass catcher
  • Weight: 66 lbs
Warranty
The Craftsman Walk Behind Mower 247.374900 comes with a 2-year full warranty, which covers any defects in materials and workmanship. This warranty extends to the engine and mower deck, but does not include wear items such as oil, spark plugs, belts, and blades. If a repair is necessary, the warranty covers the cost of this repair or, if repair is not feasible, replacement of the mower. However, it's crucial to note that the warranty becomes void if the mower is used for commercial purposes or is misused due to improper maintenance or modifications.
Craftsman 247.374900 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 10
Past 7 Days: 12
Past 30 Days: 30
All Time: 678
