5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.3743
Background
The Craftsman Walk Behind Mower 247.374300 is a lawn mower that is powered by gasoline. Produced by Sears Brands, it belongs to the Craftsman series of gardening tools. The mower is equipped with a Briggs & Stratton 163 cc OHV engine, which operates on unleaded gasoline and SAE 30 oil. It has a cutting width of 21 inches and an adjustable cutting height of 1-3.75 inches with 7 different positions. The mower operates through a push drive and its blade is made from steel alloy. Grass discharge can be done either through the side or by mulching, and the mower is started by a recoil mechanism.
This lawn mower features dual point height adjusters, allowing for quick and easy changes in cutting height. It is capable of mulching and also includes a side discharge chute. The 163cc Briggs & Stratton engine is started with a combination of a primer and recoil mechanism. The mower also features an ergonomic handle with a starter rope and blade control. It comes with a rear flap for mulching grass clippings. To operate the mower, the engine is primed three times with the primer bulb and the blade control is squeezed against the upper handle. The starter cord is then pulled to start the engine. The blade will engage while holding the blade control against the handle. If the blade control is released, the engine and blade will stop within 3 seconds.
Technical Specifications
  • Engine: Briggs & Stratton 163 cc OHV with prime and recoil start
  • Fuel: Unleaded gasoline
  • Oil: SAE 30
  • Cutting Width: 21 inches
  • Cutting Height: 1-3.75 inches (7 positions)
  • Drive: Push
  • Blade: Steel alloy
  • Grass Discharge: Side discharge or mulching
  • Start: Recoil
Warranty
The Craftsman Walk Behind Mower 247.374300 comes with a 2 year full warranty that covers defects in materials and workmanship. If any issues occur during this period, the warranty can be claimed. The process to claim the warranty usually involves providing proof of purchase, describing the issue, and following the manufacturer's instructions. The specifics can be found in the product's manual or by contacting the manufacturer. It's important to note that any issues should be reported as soon as they are noticed to ensure they fall within the warranty period.
Craftsman 247.374300 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 10
Past 7 Days: 12
Past 30 Days: 35
All Time: 555
