2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
247.37037
Background
The Craftsman 247.37037 is a walk behind lawn mower designed for residential use. It is equipped with a 140 cc Briggs & Stratton engine that operates with a recoil start. The cutting width of the mower is 21 inches, and it includes a mulching blade that helps in reducing the size of grass clippings. The height of cutting can be adjusted between 1 to 3.75 inches. The mower can be operated in two modes: mulching or bagging, with the latter involving the use of a 2.5 bushel rear grass catcher.
The Craftsman 247.37037 also has a deck wash system that allows for the cleaning of the mower deck with a garden hose. It has 7-inch front wheels and 11-inch rear wheels, and weighs approximately 60 pounds. Regular maintenance is required for optimal operation, including periodic checks of oil levels, changing of engine oil, cleaning of the air filter, and replacing the spark plug.
Technical Specifications
  • Model Number: 247.37037
  • Product Type: Walk Behind Mower
  • Engine: 140 cc Briggs & Stratton with recoil start
  • Fuel Type: Unleaded gasoline
  • Oil Type: SAE 30
  • Oil Capacity: 18 oz
  • Cutting Width: 21"
  • Cutting Height: 1-3.75" adjustable
  • Blade Type: 21" mulching blade
  • Wheel Size: 7" front, 11" rear
  • Weight: 60 lbs
Warranty
The Craftsman 247.37037 Walk Behind Mower comes with a 2-year full warranty. This warranty covers any defects in material or workmanship under normal use conditions. However, it is important to note that expendable parts like belts, blades, and blade adapters are not covered under this warranty. The engine, on the other hand, has its separate warranty covered by Briggs & Stratton. To claim the warranty, refer to the product manual for detailed instructions.
Craftsman 247.37037 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 28
All Time: 633
