2 Diagrams
Documents
Models
247.37016
Background
The Craftsman 247.370160 is a walk behind mower with a 19-inch cutting width. It is manufactured by Sears Brands and is part of their Craftsman line of products. The mower is electric and corded, with a 12 amp motor that utilizes a 120 volt AC power source. Its steel deck is equipped with a mulching blade, which can either mulch grass clippings back into the lawn or discharge them through the side or into a rear bag.
The mower's cutting height can be adjusted between 1-3/4 inches and 3-3/4 inches, providing seven different height options. It also has a foldable T-shaped handle which allows for compact storage. The mower is equipped with an overload protection switch to prevent motor overload, and an operator presence control that stops the blade when the handle is released. It weighs 52 lbs and has wheel sizes of 7 inches in the front and 8 inches in the rear.
Technical Specifications
  • Model Number: 247.370160
  • Product Type: Walk Behind Mower
  • Cutting Width: 19 inches
  • Cutting Height: 1-3/4 - 3-3/4 inches (7 positions)
  • Motor: 12 amp, 120 volt AC
  • Deck Material: Steel
  • Wheel Size: 7 inch front, 8 inch rear
  • Weight: 52 lbs
Warranty
The Craftsman Walk Behind Mower 247.370160 comes with a 2-year limited warranty provided by Sears. This warranty typically covers any defects in materials or workmanship, but it may not include wear and tear from standard use or damage caused by misuse of the product. To claim the warranty, it's usually necessary to contact Sears directly, likely through their customer service department or at one of their parts centers. Make sure to have your product's model number and proof of purchase handy when you're making a claim. It's always important to thoroughly read and understand your product's specific warranty terms for the most accurate information.
Craftsman 247.370160 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 355
