2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
358.79201, 358.792010
Background
The Craftsman 358.792010 is a gas-powered string trimmer, equipped with a two-cycle, air-cooled 28cc engine. The trimmer, which uses a mix of unleaded gasoline and synthetic two-cycle oil in a 40:1 ratio, is specifically designed for line trimming purposes. It utilizes a 0.095 inch diameter Craftsman brand line and offers a cutting width of 17 inches. Weighing approximately 10 lbs, the trimmer is equipped with a bump feed trimmer head and a line limiter blade built into the cutting shield to manage excessive line length.
The Craftsman 358.792010 is designed for a variety of landscape maintenance tasks such as trimming, edging, scalping, and sweeping. It is not intended for use in hedge trimming or pruning. To facilitate starting, the trimmer includes a primer bulb and adjustable choke settings. Usage involves operating a throttle trigger located on the underside of the assist handle, while the engine is halted through an ON/STOP switch. To ensure optimal cutting, the cutting line should be kept parallel to the ground during operation. Regular maintenance can include checks for loose fasteners, air filter cleaning, spark plug replacement, and inspection of the muffler and spark arrestor screen. At the end of the season, it is recommended to empty the fuel system, remove the spark plug, and clean external surfaces before storing in a dry location.
Technical Specifications
  • Model Number: 358.792010
  • Product Type: Gas-Powered String Trimmer
  • Engine: 28cc 2-cycle air cooled
  • Fuel Type: Unleaded gasoline mixed with synthetic 2-cycle oil at 40:1 ratio
  • Cutting Width: 17 inches
  • Cutting Line Diameter: 0.095 inch
  • Weight: 10 lbs
  • Usage: Trimming, edging, scalping, and sweeping
  • Assembly Required: Yes, includes installing the assist handle, attaching the cutting shield, and loading the cutting line.
  • Start Method: Primer bulb and adjustable choke settings
  • Operation Position: Held at waist level with the cutting head below the waist
  • Control: Throttle trigger on the underside of the assist handle, ON/STOP switch for stopping
  • Seasonal Storage: Requires emptying the fuel system, removing the spark plug, and wiping down external surfaces. Store in a dry location away from sources of ignition.
Warranty
The Craftsman 358.792010 trimmer comes with a warranty period of 2 years for consumers. This warranty is designed to cover any defects in the materials used or the workmanship involved in the production of the trimmer. If any such issues are encountered with the product, warranty service can be claimed from any Sears store or an authorized service center.
Craftsman 358.792010 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 553
