Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
315.11712
Background
The Craftsman Sander 315.117120 is a handheld tool used for smoothing various materials such as wood, metal, and plastic. Manufactured by Diehl Manufacturing Co. for Sears, this sander operates with a 3-inch wide by 21-inch long sanding belt and a 3-amp motor.
The sander contains a few key features that aid in its use. It has both front and rear handles to facilitate two-handed operation and control. A tracking adjustment feature is present to help keep the sanding belt centered. For extended usage, a lock-on button is available for continuous operation. Furthermore, a dust collection bag is attached to contain dust during use. The sander is double insulated. It is operated by securing the workpiece to prevent movement, selecting an appropriate grit sanding belt, and installing it correctly. The sander is then plugged in and allowed to reach full speed before being lowered onto the workpiece and moved across the surface. It's recommended to wipe the tool clean with a dry cloth and inspect sanding belts before use. The bearings are sealed and pre-lubricated, so no additional lubrication is required.
Technical Specifications
  • Model Number: 315.117120
  • Product Type: Sander
  • Power: 120V AC, 60Hz, 3 amps
  • Motor: 3 amp
  • Sanding belt size: 3 in x 21 in
  • Speed: 3000 SFPM
  • Weight: 5 lbs
Warranty
The Craftsman 3 Inch Belt Sander Model 315.117120 comes with a warranty of 1 year provided by Sears. This warranty covers any defects that may arise from the materials and workmanship of the product. However, it is important to note that for commercial or rental use, the warranty coverage is limited to only 90 days. In order to claim the warranty, it is required that you present proof of purchase.
Craftsman 315.117120 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 26
All Time: 734
