Up to 20% off select tools
4 Diagrams
Documents
Models
320.17543
Background
The Craftsman Router 320.17543 is a tool designed for cutting and shaping materials, especially wood. Manufactured by Chervon for Sears and sold under the Craftsman brand, it uses an 11.0 amp, 120 volt, 60Hz AC motor. The motor provides a no-load speed range between 12,000 to 25,000 RPM and can output up to 2 peak horsepower. The router is equipped with both a plunge base and a fixed base, making it versatile for different types of jobs.
The router comes with a variable speed control dial, allowing users to match the router's speed with the material and the size of the bit being used. It also includes a quick clamp system for easy switch between the fixed base and plunge base, spindle lock for one wrench bit changes, and a heavy-duty edge guide. Other features include a large base opening and chip shields for visibility, 3 LED lights to illuminate the working area, and sawdust extraction ports on both bases. There is also a live tool indicator light to show when the router is plugged in and a case for storage and transport.
Technical Specifications
  • Motor: 11.0 amp, 120 volt, 60Hz AC
  • Horsepower: 2 peak HP
  • No-load speed: 12,000 - 25,000 RPM
  • Collets: 1/4-inch and 1/2-inch self-releasing collets and nuts
  • Fixed base diameter: 6-5/8 inches
  • Plunge base diameter: 6-5/8 inches
  • Sub-base opening diameter: 1-1/4 inches
  • Sub-base thickness: 0.23 inches
  • Fixed base depth of cut capacity: 1-3/4 inches
  • Plunge base depth of cut capacity: 2-3/4 inches
Warranty
The Craftsman Router 320.17543 is covered by a full warranty for a period of 1 year, provided by Sears, Roebuck and Co. This warranty specifically covers any defects that may arise due to materials or workmanship. However, it should be noted that expendable parts such as bulbs, batteries, blades or bits are not included under this warranty coverage. In the event of a defect or malfunction, you should directly contact Sears, Roebuck and Co to claim the warranty.
Craftsman 320.17543 Owners Manual
Craftsman 320.28180 Router Table Product Manual
Craftsman Router Table 320.28160 Product Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 55
All Time: 1,219
