Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
315.275061
Background
The Craftsman Router 315.275061 is a plunge router designed for industrial purposes. Manufactured by Diehl Mfg Co for Sears under the Craftsman brand, it is equipped with a 3.5 horsepower motor and a variable speed control that allows a range of 10,000 to 25,000 RPM.
The product has several features. These include a soft start that builds motor RPM gradually, an electronic speed control that adjusts voltage to maintain RPM, a depth control knob for precise cut adjustments, and a depth stop system for quick cut changes. It also has a 1/4" and 1/2" shank capacity, a chip shield for protection, a Posilock spindle lock for bit changing, large handles for grip and control, a roller guide for uneven edges, an edge guide for routing grooves, and guide bushings for following templates.
The Craftsman Router 315.275061 can be used either handheld or mounted on a router table. Its applications cover a range of woodworking tasks including edge shaping, groove cutting, laminate trimming, and pattern routing. Proper setup, speed selection, and feed rate are factors to consider for achieving optimal results. Multi-pass cuts are preferred for better finish.
Technical Specifications
  • Product Model: 315.275061
  • Product Type: Industrial electronic plunge router
  • Motor Power: 3.5 horsepower
  • Speed Control: Variable, adjustable from 10,000 to 25,000 RPM
  • Additional Speed Control: Electronic, adjusts voltage based on motor load
  • Depth Control: Knob for precise adjustments
  • Depth Stop System: Fixed and adjustable stops for quick changes
  • Shank Capacity: 1/4" and 1/2"
  • Safety Feature: Clear plastic chip shield
  • Spindle Lock: Posilock system for easy bit changes
  • Handle Size: Large for better grip and control
  • Additional Features: Roller guide for uneven edges and edge guide for parallel routing
  • No Load Speed: 25,000 RPM
  • Power Draw: 15 Amps
  • Voltage: 120V AC, 60Hz
  • Base Dimensions: 6" x 6"
  • Weight: 10 lbs
Warranty
The Craftsman Router 315.275061 comes with a one-year warranty. This warranty term commences from the date of purchase and offers coverage for any manufacturing defects that may arise during this period. To claim the warranty, it is typically necessary to provide proof of purchase, such as an invoice or a receipt, and to contact the Sears customer service team who will guide you through the warranty claim process. The warranty does not cover damage caused by accidents, misuse, or normal wear and tear.
Craftsman 315.275061 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 568
